nvidia display settings missing
2024-02-15T05:08:08+00:00
nvidia control panel is missing display settings, in my laptop it only shows 3d settings and developer, please help thanks
    2025-01-09T13:25:59+00:00
    THIS - people - IS the answer. Plug your HDMI into your graphics card - NOT the HDMI socket on your pc. I never appreciated the difference until reading this. Plug it into the card and the Display settings miraculously appear. Big thanks to Con H. :-)
    2025-01-10T05:55:55+00:00
    I have a laptop
    2025-01-12T14:50:17+00:00
    Hey I also have the same problem
    2025-01-14T20:55:59+00:00
    What if there isn't anything named nvidia control panel???
    2025-03-02T15:19:02+00:00
    i have same problem. and this how i fix it :
    go to BIOS by press F2, search "Graphic Device" >> Change to "discrete". Save and Reboot. (I use Lenovo Legion y740 so i not sure if it same for you)
    or
    you can search "how to Disable Integrated Onboard Gaphics Card on BIOS"
    Good Luck
