Alright. I’ll send it once I get another BSOD.
I’ve had repeated blue screens and I’m not sure how to fix them.
I’ve had these issues for about a year and we’ve tried replacing the RAM,GPU and my SSD but I still have them.
Down below is my mini dump file
KERNEL_SECURITY_CHECK_FAILURE (139) A kernel component has corrupted a critical data structure. The corruption could potentially allow a malicious user to gain control of this machine. Arguments: Arg1: 0000000000000003, A LIST_ENTRY has been corrupted (i.e. double remove). Arg2: ffffe086247105d0, Address of the trap frame for the exception that caused the BugCheck Arg3: ffffe08624710528, Address of the exception record for the exception that caused the BugCheck Arg4: 0000000000000000, Reserved Debugging Details: ------------------ *** WARNING: Check Image - Checksum mismatch - Dump: 0xaf228, File: 0xb62c4 - C:\ProgramData\Dbg\sym\afd.sys\3E047898a8000\afd.sys KEY_VALUES_STRING: 1 Key : Analysis.CPU.mSec Value: 1499 Key : Analysis.Elapsed.mSec Value: 4941 Key : Analysis.IO.Other.Mb Value: 0 Key : Analysis.IO.Read.Mb Value: 0 Key : Analysis.IO.Write.Mb Value: 1 Key : Analysis.Init.CPU.mSec Value: 124 Key : Analysis.Init.Elapsed.mSec Value: 4790 Key : Analysis.Memory.CommitPeak.Mb Value: 91 Key : Bugcheck.Code.LegacyAPI Value: 0x139 Key : Dump.Attributes.AsUlong Value: 8 Key : Dump.Attributes.KernelGeneratedTriageDump Value: 1 Key : FailFast.Name Value: CORRUPT_LIST_ENTRY Key : FailFast.Type Value: 3 Key : Failure.Bucket Value: 0x139_3_CORRUPT_LIST_ENTRY_KTIMER_LIST_CORRUPTION_nt!KiTimerWaitTest Key : Failure.Hash Value: {efb56395-a173-53f8-073d-d3c8cfd50e2b} BUGCHECK_CODE: 139 BUGCHECK_P1: 3 BUGCHECK_P2: ffffe086247105d0 BUGCHECK_P3: ffffe08624710528 BUGCHECK_P4: 0 FILE_IN_CAB: 021124-4515-01.dmp DUMP_FILE_ATTRIBUTES: 0x8 Kernel Generated Triage Dump TRAP_FRAME: ffffe086247105d0 -- (.trap 0xffffe086247105d0) NOTE: The trap frame does not contain all registers. Some register values may be zeroed or incorrect. rax=ffff940db3ba5158 rbx=0000000000000000 rcx=0000000000000003 rdx=ffff940db0c303d8 rsi=0000000000000000 rdi=0000000000000000 rip=fffff805394401d6 rsp=ffffe08624710760 rbp=ffffa88147451180 r8=0000000000000102 r9=0000000000000000 r10=fffff8053720bd80 r11=fffff80549064b90 r12=0000000000000000 r13=0000000000000000 r14=0000000000000000 r15=0000000000000000 iopl=0 nv up ei pl nz ac pe cy nt!KiTryUnwaitThread+0x1da9d6: fffff805394401d6 cd29 int 29h Resetting default scope EXCEPTION\_RECORD: ffffe08624710528 -- (.exr 0xffffe08624710528) ExceptionAddress: fffff805394401d6 (nt!KiTryUnwaitThread+0x00000000001da9d6) ExceptionCode: c0000409 (Security check failure or stack buffer overrun) ExceptionFlags: 00000001 NumberParameters: 1 Parameter[0]: 0000000000000003 Subcode: 0x3 FAST\_FAIL\_CORRUPT\_LIST\_ENTRY CUSTOMER\_CRASH\_COUNT: 1 PROCESS\_NAME: System ERROR\_CODE: (NTSTATUS) 0xc0000409 - The system detected an overrun of a stack-based buffer in this application. This overrun could potentially allow a malicious user to gain control of this application. EXCEPTION\_CODE\_STR: c0000409 EXCEPTION\_PARAMETER1: 0000000000000003 EXCEPTION\_STR: 0xc0000409 STACK\_TEXT: ffffe086247102a8 fffff8053942c4e9 : 0000000000000139 0000000000000003 ffffe086247105d0 ffffe08624710528 : nt!KeBugCheckEx ffffe086247102b0 fffff8053942cab2 : 0000000000000000 0000000000000000 0000000000000000 0000000000000000 : nt!KiBugCheckDispatch+0x69 ffffe086247103f0 fffff8053942a806 : 0000000000000000 0000000000000000 ffffa2ed63fded5b 0000000000000000 : nt!KiFastFailDispatch+0xb2 ffffe086247105d0 fffff805394401d6 : fffff8053720f6a0 fffff80537208180 fffff8053720bd80 0000000000000002 : nt!KiRaiseSecurityCheckFailure+0x346 ffffe08624710760 fffff8053927675c : ffff940db3ba5188 ffffe08600000000 ffff940db3ba5250 fffff80549065699 : nt!KiTryUnwaitThread+0x1da9d6 ffffe086247107c0 fffff8053927629a : ffff940db3ba5180 ffff940da81ca000 ffffe08624710af8 0000000000000002 : nt!KiTimerWaitTest+0x1fc ffffe08624710860 fffff80539273084 : 0000000000000000 0000000000000000 0000000000000000 fffff8053720e328 : nt!KiProcessExpiredTimerList+0xda ffffe08624710990 fffff8053941baee : 0000000000000000 ffffa88147451180 ffff940da6f95040 ffff940dacd8a080 : nt!KiRetireDpcList+0xaf4 ffffe08624710c40 0000000000000000 : ffffe08624711000 ffffe0862470b000 0000000000000000 00000000`00000000 : nt!KiIdleLoop+0x9e SYMBOL_NAME: nt!KiTimerWaitTest+1fc MODULE_NAME: nt IMAGE_NAME: ntkrnlmp.exe IMAGE_VERSION: 10.0.22621.3085 STACK_COMMAND: .cxr; .ecxr ; kb BUCKET_ID_FUNC_OFFSET: 1fc FAILURE_BUCKET_ID: 0x139_3_CORRUPT_LIST_ENTRY_KTIMER_LIST_CORRUPTION_nt!KiTimerWaitTest OSPLATFORM_TYPE: x64 OSNAME: Windows 10 FAILURE_ID_HASH: {efb56395-a173-53f8-073d-d3c8cfd50e2b} Followup: MachineOwner ---------
2024-02-18T00:40:33+00:00 -
Jonathan Deives 81,795 Reputation points Independent Advisor2024-02-18T00:41:27+00:00 I await your reply
2024-02-18T01:17:16+00:00 just got a bsod here the file link.
https://www.dropbox.com/scl/fo/nq99yh0d2919efmc165mg/h?rlkey=94l5yuzezcj3posuk1ugv05kt&dl=0
Jonathan Deives 81,795 Reputation points Independent Advisor2024-02-18T01:19:23+00:00 What processor and motherboard are you using?
2024-02-18T01:22:41+00:00 AMD Ryzen 5 3600 and a ASRock B550 PG Velocita
