why a problem with 2024-04 Cumulative Update for Windows 11 Version 23H2 for x64-based System (KB5036893) "ERROR TO INSTALL"
2024-04-10T02:56:57+00:00
This update has a serious problem. I was checking and it doesn't install along with the others. The Framework update came out and I had to install it alone. That installed without problems. But the update
Install from the updates panel. but when it asks to restart, while Windows is loading, I get the message that it has to reverse the update because it has an error.
I downloaded the file directly from Microsoft to check if it was my computer. But it gave me the same error notice.
My question is: What happened to the update that is giving an error after installing it from the panel, and why do I get the same error with the downloaded file?
Here are the photos I took.
    2024-05-20T10:54:01+00:00
    • Open services.msc. Double-click "App Readiness" and set it to Manual.
    This advice turned out to be helpful and working with my case too.
    Thank you!
    2024-05-20T13:16:34+00:00
    Yes, and I also restarted. Like I mentioned, this happened the first day I got my new laptop. Hasn't updated since, so it's never fully been up to date.
