cloned OS drive "System Reserved" partition Not 100% afterwards.
2024-06-24T15:29:41+00:00
I cloned my OS drive twice to move to a newer hardware. But the last time, it seems the "System Reserved" partition of the drive had some issues.  1st: it is not showing "System Reserved" on that partition.  2nd: the following attributes "system, Active, MBR" are not on it and shows only "Primary".  My PC still boots up, but the whole purpose of this exercise was to get compatible to install Windows 11 and upgrade the OS drive with new and faster hardware.  My questions are:
Is there anything I can do to fix it other than re-installing the OS?
Is this going to cause any issue with upgrade to Windows 11?
See below properties of this partition.
Device SCSI\Disk&Ven_NVMe&Prod_CT2000T705SSD3\5&2384875e&0&000000 was not migrated due to partial or ambiguous match.
Last Device Instance Id: SCSI\Disk&Ven_Samsung&Prod_SSD_870_QVO_1TB\4&fa535c2&0&000000
Class Guid: {4d36e967-e325-11ce-bfc1-08002be10318}
Location Path:
Migration Rank: 0xF000FF001001F020
Present: false
Status: 0xC00007196/15/2024 10:51:31 AM Device not migrated
6/15/2024 10:51:31 AM Device configured (disk.inf)
Device SCSI\Disk&Ven_NVMe&Prod_CT2000T705SSD3\5&2384875e&0&000000 was configured.
Driver Name: disk.inf
Driver Date: 06/21/2006
Driver Version: 10.0.19041.4355
Driver Provider: Microsoft
Driver Section: disk_install.NT
Driver Rank: 0xFF0007
Matching Device Id: GenDisk
Outranked Drivers:
Device Updated: false
Parent Device: PCI\VEN_C0A9&DEV_542B&SUBSYS_2B00C0A9&REV_00\4&2ec11bf&0&000A
6/15/2024 10:51:31 AM Device started (disk)
Device SCSI\Disk&Ven_NVMe&Prod_CT2000T705SSD3\5&2384875e&0&000000 was started.
Service: disk
Lower Filters:
Upper Filters:
Thank you.
Ramesh 181.8K Reputation points Volunteer Moderator
2024-07-11T15:15:35+00:00
You're welcome, Givi. Glad to have helped. 👍
You may close this thread by marking helpful posts as answers if there are no further questions. How to mark Your question as "Answered".
56 additional answers
  1. Ramesh 181.8K Reputation points Volunteer Moderator
    2024-07-08T15:14:48+00:00
    Givi,
    Please create a Windows 10 USB setup disk to boot into WinRE.
    How to Make a Bootable Windows 10 USB Drive: https://www.howtogeek.com/787937/how-to-make-a-bootable-windows-10-usb-drive/
    After creating the USB setup disk, boot the computer using it. To do so, you may need to change the boot order in the BIOS/UEFI settings. Consult your system or motherboard manual to learn how to access the UEFI settings for your model.
    In the Windows Setup screen, select the Language and click Next.
    Press Shift + F10 to open WinRE Command Prompt.
    Run the following commands:
    • diskpart
    • list disk
    • select disk 1
    • create partition EFI
    • list part
    • list vol
    Take a photo of the output window and post it here.
    2024-07-08T15:57:18+00:00
    Hi Ramesh,
    I hope this helps. Please let me know if you need anyuthing else.
    Microsoft Windows [Version 10.0.19045.4598]
    (c) Microsoft Corporation. All rights reserved.
    C:\WINDOWS\system32>diskpart
    Microsoft DiskPart version 10.0.19041.3636
    Copyright (C) Microsoft Corporation.
    On computer: BADASSPC
    DISKPART> list disk
    Disk ### Status Size Free Dyn Gpt
    Disk 0 Online 931 GB 0 B
    Disk 1 Online 1863 GB 0 B *
    Disk 2 Online 1863 GB 931 GB
    Disk 3 No Media 0 B 0 B
    DISKPART> select disk 1
    Disk 1 is now the selected disk.
    DISKPART> list part
    Partition ### Type Size Offset
    Partition 1 System 500 MB 1024 KB
    Partition 2 Primary 1861 GB 501 MB
    Partition 3 System 100 MB 1862 GB
    Partition 4 Recovery 567 MB 1862 GB
    DISKPART> list vol
    Volume ### Ltr Label Fs Type Size Status Info
    Volume 0 E DVD-ROM 0 B No Media
    Volume 1 G DVD-ROM 0 B No Media
    Volume 2 D NTFS Partition 931 GB Healthy
    Volume 3 C NTFS Partition 1861 GB Healthy Boot
    Volume 4 RAW Partition 500 MB Healthy Hidden
    Volume 5 FAT32 Partition 100 MB Healthy System
    Volume 6 NTFS Partition 567 MB Healthy Hidden
    Volume 7 S E:\ NTFS Partition 931 GB Healthy
    Volume 8 H Removable 0 B No Media
    DISKPART>
    Regards,
    Givi
  3. Ramesh 181.8K Reputation points Volunteer Moderator
    2024-07-08T16:43:47+00:00
    You need to open WinRE Command Prompt and run those commands. Not from the admin Command Prompt (ie.., when Windows is running)
    2024-07-08T18:13:46+00:00
    Hi Ramesh,
    I did boot from a Windows 10 CD and went to the Troubleshooting-->Advance Option-->Command Prompt . Then ran the commands and created the Partition for EFI. I could not save the screen shot so when I booted back I just sent you the output. Didn't do the create part again.
    It looks like the Disk-1 Partiotion_1 is now (EFI System Partition).
    Let me know if you think I need to redo it.
    Thanks.
    Givi
