You're welcome, Givi. Glad to have helped. 👍
You may close this thread by marking helpful posts as answers if there are no further questions. How to mark Your question as "Answered".
I cloned my OS drive twice to move to a newer hardware. But the last time, it seems the "System Reserved" partition of the drive had some issues. 1st: it is not showing "System Reserved" on that partition. 2nd: the following attributes "system, Active, MBR" are not on it and shows only "Primary". My PC still boots up, but the whole purpose of this exercise was to get compatible to install Windows 11 and upgrade the OS drive with new and faster hardware. My questions are:
Is there anything I can do to fix it other than re-installing the OS?
Is this going to cause any issue with upgrade to Windows 11?
See below properties of this partition.
Device SCSI\Disk&Ven_NVMe&Prod_CT2000T705SSD3\5&2384875e&0&000000 was not migrated due to partial or ambiguous match.
Last Device Instance Id: SCSI\Disk&Ven_Samsung&Prod_SSD_870_QVO_1TB\4&fa535c2&0&000000
Class Guid: {4d36e967-e325-11ce-bfc1-08002be10318}
Location Path:
Migration Rank: 0xF000FF001001F020
Present: false
Status: 0xC00007196/15/2024 10:51:31 AM Device not migrated
6/15/2024 10:51:31 AM Device configured (disk.inf)
Device SCSI\Disk&Ven_NVMe&Prod_CT2000T705SSD3\5&2384875e&0&000000 was configured.
Driver Name: disk.inf
Driver Date: 06/21/2006
Driver Version: 10.0.19041.4355
Driver Provider: Microsoft
Driver Section: disk_install.NT
Driver Rank: 0xFF0007
Matching Device Id: GenDisk
Outranked Drivers:
Device Updated: false
Parent Device: PCI\VEN_C0A9&DEV_542B&SUBSYS_2B00C0A9&REV_00\4&2ec11bf&0&000A
6/15/2024 10:51:31 AM Device started (disk)
Device SCSI\Disk&Ven_NVMe&Prod_CT2000T705SSD3\5&2384875e&0&000000 was started.
Service: disk
Lower Filters:
Upper Filters:
Thank you.
Hi Givi,
Any update on this? Let me know how the conversion went.
Hi Ramesh,
Thank you so much for your patience and guidance. I had to run a couple of backups before all this. Please see below the output of the command you sent, it is positive and I am very happy. Please let me know if there is a good site to start and upgrade to Windows 11. Not sure what this message is about "Call WinReReapir to repair WinRE" . ;-)
Microsoft Windows [Version 10.0.19045.4598]
(c) Microsoft Corporation. All rights reserved.
C:\Windows\system32>
C:\Windows\system32>MBR2GPT /convert /disk:1 /allowFullOS
MBR2GPT will now attempt to convert disk 1.
If conversion is successful the disk can only be booted in GPT mode.
These changes cannot be undone!
MBR2GPT: Attempting to convert disk 1
MBR2GPT: Retrieving layout of disk
MBR2GPT: Validating layout, disk sector size is: 512 bytes
MBR2GPT: Trying to shrink the OS partition
MBR2GPT: Creating the EFI system partition
MBR2GPT: Installing the new boot files
MBR2GPT: Performing the layout conversion
MBR2GPT: Migrating default boot entry
MBR2GPT: Fixing drive letter mapping
MBR2GPT: Conversion completed successfully
Regards,
Givi
Regarding the error message "Call WinReReapir to repair WinRE", please try to enable WinRE using the following command:
Press Enter.
Then, run:
Please post the output here.
Also, post a screenshot of Disk Management.
Here's a guide on how to upgrade to Windows 11 using the ISO.
How to run In-place upgrade in Windows 11 - Microsoft Community: https://answers.microsoft.com/en-us/windows/forum/all/how-to-run-in-place-upgrade-in-windows-11/4d469147-2747-4dcb-88a4-aae9273a4500
Hi Ramesh,
Please see below outputs, they are positive;
C:\Windows\system32>reagentc /enable
REAGENTC.EXE: Operation Successful.
C:\Windows\system32>reagentc /info
Windows Recovery Environment (Windows RE) and system reset configuration
Information:
Windows RE status: Enabled
Windows RE location: \\?\GLOBALROOT\device\harddisk1\partition2\Recovery\WindowsRE
Boot Configuration Data (BCD) identifier: d3fbf947-3b30-11ef-9513-d880838240e6
Recovery image location:
Recovery image index: 0
Custom image location:
Custom image index: 0
Thank you.
