cloned OS drive "System Reserved" partition Not 100% afterwards.
2024-06-24T15:29:41+00:00
I cloned my OS drive twice to move to a newer hardware. But the last time, it seems the "System Reserved" partition of the drive had some issues.  1st: it is not showing "System Reserved" on that partition.  2nd: the following attributes "system, Active, MBR" are not on it and shows only "Primary".  My PC still boots up, but the whole purpose of this exercise was to get compatible to install Windows 11 and upgrade the OS drive with new and faster hardware.  My questions are:
Is there anything I can do to fix it other than re-installing the OS?
Is this going to cause any issue with upgrade to Windows 11?
See below properties of this partition.
Device SCSI\Disk&Ven_NVMe&Prod_CT2000T705SSD3\5&2384875e&0&000000 was not migrated due to partial or ambiguous match.
Last Device Instance Id: SCSI\Disk&Ven_Samsung&Prod_SSD_870_QVO_1TB\4&fa535c2&0&000000
Class Guid: {4d36e967-e325-11ce-bfc1-08002be10318}
Location Path:
Migration Rank: 0xF000FF001001F020
Present: false
Status: 0xC00007196/15/2024 10:51:31 AM Device not migrated
6/15/2024 10:51:31 AM Device configured (disk.inf)
Device SCSI\Disk&Ven_NVMe&Prod_CT2000T705SSD3\5&2384875e&0&000000 was configured.
Driver Name: disk.inf
Driver Date: 06/21/2006
Driver Version: 10.0.19041.4355
Driver Provider: Microsoft
Driver Section: disk_install.NT
Driver Rank: 0xFF0007
Matching Device Id: GenDisk
Outranked Drivers:
Device Updated: false
Parent Device: PCI\VEN_C0A9&DEV_542B&SUBSYS_2B00C0A9&REV_00\4&2ec11bf&0&000A
6/15/2024 10:51:31 AM Device started (disk)
Device SCSI\Disk&Ven_NVMe&Prod_CT2000T705SSD3\5&2384875e&0&000000 was started.
Service: disk
Lower Filters:
Upper Filters:
Thank you.
Ramesh 181.8K Reputation points Volunteer Moderator
2024-07-11T15:15:35+00:00
You're welcome, Givi. Glad to have helped. 👍
You may close this thread by marking helpful posts as answers if there are no further questions. How to mark Your question as "Answered".
56 additional answers
  1. Ramesh 181.8K Reputation points Volunteer Moderator
    2024-07-11T14:45:13+00:00
    Try:
    • diskpart
    • select disk 1
    • select part 3
    • set id=de94bba4-06d1-4d40-a16a-bfd50179d6ac override
    • gpt attributes=0x8000000000000001
    • exit
    • reagentc /info
    2024-07-11T14:57:35+00:00
    Hi Ramesh,
    It looks much better and no issues, thanks. See below outputs and screeen shot.
    DISKPART> select disk 1
    Disk 1 is now the selected disk.
    DISKPART> list part
    Partition ### Type Size Offset
    Partition 1 System 500 MB 1024 KB
    Partition 2 Primary 1861 GB 501 MB
    Partition 3 Primary 1053 MB 1861 GB
    DISKPART> select part 3
    Partition 3 is now the selected partition.
    DISKPART> set id=de94bba4-06d1-4d40-a16a-bfd50179d6ac override
    DiskPart successfully set the partition ID.
    DISKPART> gpt attributes=0x8000000000000001
    DiskPart successfully assigned the attributes to the selected GPT partition.
    DISKPART> exit
    Leaving DiskPart...
    C:\Windows\System32>reagentc /info
    Windows Recovery Environment (Windows RE) and system reset configuration
    Information:
    Windows RE status:         Enabled
    Windows RE location:       \\?\GLOBALROOT\device\harddisk1\partition3\Recovery\WindowsRE
    Boot Configuration Data (BCD) identifier: af072328-3edb-11ef-9529-83e3b04918e0
    Recovery image location:
    Recovery image index:      0
    Custom image location:
    Custom image index:        0
    REAGENTC.EXE: Operation Successful.
  3. Ramesh 181.8K Reputation points Volunteer Moderator
    2024-07-11T15:00:07+00:00
    Great, everything looks good.
    2024-07-11T15:06:26+00:00
    Ramesh,
    Thank you very much for your help and persistance in this matter, it was great working with you. I am very happy about the work that you did. Take care.
    Regards,
    Givi
