You're welcome, Givi. Glad to have helped. 👍
You may close this thread by marking helpful posts as answers if there are no further questions. How to mark Your question as "Answered".
I cloned my OS drive twice to move to a newer hardware. But the last time, it seems the "System Reserved" partition of the drive had some issues. 1st: it is not showing "System Reserved" on that partition. 2nd: the following attributes "system, Active, MBR" are not on it and shows only "Primary". My PC still boots up, but the whole purpose of this exercise was to get compatible to install Windows 11 and upgrade the OS drive with new and faster hardware. My questions are:
Is there anything I can do to fix it other than re-installing the OS?
Is this going to cause any issue with upgrade to Windows 11?
See below properties of this partition.
Device SCSI\Disk&Ven_NVMe&Prod_CT2000T705SSD3\5&2384875e&0&000000 was not migrated due to partial or ambiguous match.
Last Device Instance Id: SCSI\Disk&Ven_Samsung&Prod_SSD_870_QVO_1TB\4&fa535c2&0&000000
Class Guid: {4d36e967-e325-11ce-bfc1-08002be10318}
Location Path:
Migration Rank: 0xF000FF001001F020
Present: false
Status: 0xC00007196/15/2024 10:51:31 AM Device not migrated
6/15/2024 10:51:31 AM Device configured (disk.inf)
Device SCSI\Disk&Ven_NVMe&Prod_CT2000T705SSD3\5&2384875e&0&000000 was configured.
Driver Name: disk.inf
Driver Date: 06/21/2006
Driver Version: 10.0.19041.4355
Driver Provider: Microsoft
Driver Section: disk_install.NT
Driver Rank: 0xFF0007
Matching Device Id: GenDisk
Outranked Drivers:
Device Updated: false
Parent Device: PCI\VEN_C0A9&DEV_542B&SUBSYS_2B00C0A9&REV_00\4&2ec11bf&0&000A
6/15/2024 10:51:31 AM Device started (disk)
Device SCSI\Disk&Ven_NVMe&Prod_CT2000T705SSD3\5&2384875e&0&000000 was started.
Service: disk
Lower Filters:
Upper Filters:
Thank you.
Hi Ramesh,
OK, we are Windows 11, YEAH...Thank you so much for your assistance. It was grate.
Please see below outputs and let me know if we have anythiing else to look into or to do, such as the 101MB unallocated part.
Regards,
C:\Windows\System32>diskpart
Microsoft DiskPart version 10.0.22621.1
Copyright (C) Microsoft Corporation.
On computer: BADASSPC
DISKPART> list disk
Disk ### Status Size Free Dyn Gpt
Disk 0 Online 931 GB 0 B
Disk 1 Online 1863 GB 101 MB *
Disk 2 Online 1863 GB 931 GB
Disk 3 No Media 0 B 0 B
DISKPART> select disk 1
Disk 1 is now the selected disk.
DISKPART> list vol
Volume ### Ltr Label Fs Type Size Status Info
Volume 0 E DVD-ROM 0 B No Media
Volume 1 G ESD-ISO UDF DVD-ROM 5400 MB Healthy
Volume 2 D NTFS Partition 931 GB Healthy
Volume 3 C NTFS Partition 1861 GB Healthy Boot
Volume 4 FAT32 Partition 500 MB Healthy System
Volume 5 NTFS Partition 953 MB Healthy Hidden
Volume 6 S E:\ NTFS Partition 931 GB Healthy
Volume 7 I Removable 0 B No Media
DISKPART>
Givi
Suggest to temporarily convert Disk 1 partition 3 to basic and extend it in disk management...
Givi,
Great.
What Volume Z said. You can merge that 101 MB unallocated space with the Recovery partition.
Open CMD as admin.
Run:
Open Disk Management and extend the Recovery partition. Once done, run the following:
Post the output for the last command.
Hi Ramesh,
The first part went OK, see below. But the disk partition is in use, so it did not take the id. It says use OVERRIDE parameters. So, please let me know . Thank you.
DISKPART> list disk
DISKPART> list part
Partition ### Type Size Offset
Partition 1 System 500 MB 1024 KB
Partition 2 Primary 1861 GB 501 MB
Partition 3 Recovery 953 MB 1861 GB
DISKPART> select part3
DISK - Shift the focus to a disk. For example, SELECT DISK.
PARTITION - Shift the focus to a partition. For example, SELECT PARTITION.
VOLUME - Shift the focus to a volume. For example, SELECT VOLUME.
VDISK - Shift the focus to a virtual disk. For example, SELECT VDISK.
DISKPART> select part 3
Partition 3 is now the selected partition.
DISKPART> set id=ebd0a0a2-b9e5-4433-87c0-68b6b72699c7
DiskPart successfully set the partition ID.
DISKPART> gpt attributes=0x0000000000000000
DiskPart successfully assigned the attributes to the selected GPT partition.
DISKPART> exit
Leaving DiskPart...
DISKPART> list disk
Disk 1 Online 1863 GB 1024 KB *
DISKPART> list part
Partition 3 Primary 1053 MB 1861 GB
DISKPART> set id=de94bba4-06d1-4d40-a16a-bfd50179d6ac
Virtual Disk Service error:
The device is in use.
The selected volume or partition is in use.
To continue with the operation use the OVERRIDE parameter.
DISKPART>
