You're welcome, Givi. Glad to have helped. 👍
You may close this thread by marking helpful posts as answers if there are no further questions. How to mark Your question as "Answered".
I cloned my OS drive twice to move to a newer hardware. But the last time, it seems the "System Reserved" partition of the drive had some issues. 1st: it is not showing "System Reserved" on that partition. 2nd: the following attributes "system, Active, MBR" are not on it and shows only "Primary". My PC still boots up, but the whole purpose of this exercise was to get compatible to install Windows 11 and upgrade the OS drive with new and faster hardware. My questions are:
Is there anything I can do to fix it other than re-installing the OS?
Is this going to cause any issue with upgrade to Windows 11?
See below properties of this partition.
Device SCSI\Disk&Ven_NVMe&Prod_CT2000T705SSD3\5&2384875e&0&000000 was not migrated due to partial or ambiguous match.
Last Device Instance Id: SCSI\Disk&Ven_Samsung&Prod_SSD_870_QVO_1TB\4&fa535c2&0&000000
Class Guid: {4d36e967-e325-11ce-bfc1-08002be10318}
Location Path:
Migration Rank: 0xF000FF001001F020
Present: false
Status: 0xC00007196/15/2024 10:51:31 AM Device not migrated
6/15/2024 10:51:31 AM Device configured (disk.inf)
Device SCSI\Disk&Ven_NVMe&Prod_CT2000T705SSD3\5&2384875e&0&000000 was configured.
Driver Name: disk.inf
Driver Date: 06/21/2006
Driver Version: 10.0.19041.4355
Driver Provider: Microsoft
Driver Section: disk_install.NT
Driver Rank: 0xFF0007
Matching Device Id: GenDisk
Outranked Drivers:
Device Updated: false
Parent Device: PCI\VEN_C0A9&DEV_542B&SUBSYS_2B00C0A9&REV_00\4&2ec11bf&0&000A
6/15/2024 10:51:31 AM Device started (disk)
Device SCSI\Disk&Ven_NVMe&Prod_CT2000T705SSD3\5&2384875e&0&000000 was started.
Service: disk
Lower Filters:
Upper Filters:
Thank you.
Hi Ramesh,
Sorry about that. I went to the WinRE again and replaced c:\ to D:\ and this time it worked, see the photo below. I then booted up and from Admin command prompt ran "bcdedit", see the output below.
Thank you. Let me know,
Microsoft Windows [Version 10.0.19045.4598]
(c) Microsoft Corporation. All rights reserved.
C:\windows\system32>bcdedit
Windows Boot Manager
identifier {bootmgr}
device partition=\Device\HarddiskVolume1
path \EFI\Microsoft\Boot\bootmgfw.efi
description Windows Boot Manager
locale en-us
inherit {globalsettings}
default {current}
resumeobject {15b009e4-3eed-11ef-b054-f93f06865efa}
displayorder {current}
toolsdisplayorder {memdiag}
timeout 30
Windows Boot Loader
identifier {current}
device partition=C:
path \windows\system32\winload.efi
description Windows 10
locale en-us
inherit {bootloadersettings}
isolatedcontext Yes
allowedinmemorysettings 0x15000075
osdevice partition=C:
systemroot \windows
nx OptIn
bootmenupolicy Standard
Thanks. The H: volume can be deleted now, and the free space can be merged with C:.
Upgrade to Windows 11 and let's know how it goes.
Thanks Ramesh,
OK. We'll upgrade tp Win-11 and then remove H:\ and add it to C:\ . What is going to happen to the 568MB unallocated part on disk-1?
I'll let you know how it went.
Regards,
Givi
Please delete H:\ and merge the free space first. This is because the setup can resize the recovery partition (if required) only if it's adjacent to the OS partition. If the setup doesn't automatically configure WinRE, we can do it manually.
