Why am I being asked for a Passkey? How do I turn off passkeys?
2024-07-22T21:51:35+00:00
I was opted into this without my knowledge, or without understanding how it works.
I have a solid understanding of Windows, and the security around it. But I do not understand why I suddenly am being forced to use, and constantly asked about passkeys, when I have not opted into them or set them up.
If I don't understand why I am being forced to use these, or why they are required, none of the less savvy users will. This will likely result in Microsoft spending more on tech support due to people being locked out of their devices.
Scenario: I have deleted the passkeys from my settings, and now my Edge logins have a discrepancy, because they are demanding passkeys that no longer exist.
For some reason, Windows is not allowing me to delete my Microsoft Passkey, because now that is required to sign in to my computer. I already have a PIN, a password, a fingerprint, and my face to sign in to my computer.
Is the only option logging out of my Microsoft Account and making it a local account to opt out of passkeys?
Passkeys need to be explained better if they are going to be a requirement, it needs to be a more gentle introduction.
Rob Koch 26,160 Reputation points Volunteer Moderator
2024-07-23T03:59:03+00:00
You've been using a passkey to login to Windows since you enabled Windows Hello to perform Face, Fingerprint or PIN login methods, since they' re an integral part of that system. They simply weren't as visible in the past, since the Passkey Management and using them for 3rd-party apps or websites weren't yet supported.
As usual, the problem is there are many documents available covering these and some confusing differences between the Azure Business-based systems using something called Entra for authentication and the consumer version of these related to your Microsoft Personal account. I'll include documents from both here in case you are more technically interested but tell you which I'm providing.
The first is an overview for consumer accounts and should help you understand how crucial they are to Microsoft's future authentication systems intended to remove the need for passwords, so trying to escae them is utterly pointless.
New passkey support for Microsoft consumer accounts | Microsoft Security Blog
This next one has more technical detail and in the first sections describes in general how they work, while a later section is specific to the Microsoft implementation and shows how these functions relate to Windows Hello, the Edge browser and other similar portions of Windows. I wouldn't typically provide this to the average consumer, but it really makes their operation on Windows clear for those wanting to understand them more deeply.
WebAuthn APIs - Windows Security | Microsoft Learn
I think I'll stop there for the moment to make sure you want more iformation, since upon quick review, these two documents cover the basics, while there are many others that provide the How-to explanations for individual portions of passkey operation.
Rob
< EDIT > BTW, here's a FAQ document with some common questions about passkeys, the last of which is titled; How can I provide feedback about my experience with passkeys?
Passkeys frequently asked questions (FAQ) - Microsoft Support
If you click the question to view the answer, you'll find a link to the Windows Feedback where you can submit your comments directly to Microsoft. Anything you post in this forum will only be seen by those who browse here, while virtually no Microsoft employees ever do and so your posts here are only really seen by us volunteer or a few contract helpers.
quietman7 MVP Alumni 19,830 Reputation points Volunteer Moderator
2025-06-22T21:08:03+00:00
I appreciate your response. If a password and the multi-authentication code is not sufficient, what does a 'passkey' do?
Why doesn't Microsoft provide some easy-to-understand explanation of what a 'passkey' is and why it is different for every site?
I provided that information in a previous reply (page 11) but here are those and some more links by Microsoft with explanations.
Passkeys Authentication Across Platforms - How Passkeys Registration and Authentication Work Across Devices and Platforms
Quote
To combat such risks, phishing-resistant Passwordless authentication methods, including enhanced support for Microsoft Authenticator, have become critical.
Just for the record...Microsoft has long been a proponent of passwordless authentication for years so this is nothing new. Other industries have been moving in that direction too. .
In a nutshell...Passkeys are stored as secrets locally on a device and use a device's unlock mechanism such as Windows Hello biometrics (fingerprint or facial recognition) or PIN sign-In options to authenticate them before signing in. Passkeys can be used without the need for other sign-in challenges, making the authentication process faster and more convenient. A passkey is invisible, virtual and employ public-key cryptography (keypair concept: a private key and a public key). The passkey is purposely hidden from access inside the TPM (Trusted Platform Module).
TPM chip is an embedded crypto-processor in laptops and is designed to provide hardware-based, security-related functions (carry out cryptographic operations. The TPM is isolated from the main processor and functions as a vault (a lockbox for keys) so in the event of malware attack or breach, sensitive user data remains secure.
129 additional answers
    2025-06-16T17:02:18+00:00
    That's part of the password function of chrome and edge browsers. Goes away if you turn off password saving. I use the free version of Avira password manager. If your used to using google for passwords it can be a bit of a change.
    2025-06-16T17:26:51+00:00
    Unfortunately, no, the "Do you want fries, er, passkeys with that?" prompts do not go away with disabling Chrome's built-in password manager. I've used LastPass since 2009, and I have all browsers' built-in password managers disabled. These prompts still appear :-(
  3. Rob Koch 26,160 Reputation points Volunteer Moderator
    2025-06-16T19:54:39+00:00
    Yep, that's Chrome doing that, so a quick search found this thread that sounds like a similar issue to me.
    Chrome on Win11 - disable QR code passkey popup and skip to USB security key? : r/yubikey
    Not sure whether that's the same exact issue you're having, but it sounds more similar than anything I've seen mentioned in these forums. It also seems to fit in with the issues that the developer's article someone, (maybe you?) referenced regarding the problems created when the FIDO Alliance pulled the section of the specification related to 3rd-party authenticators, and all of the workarounds that have become necessary as a result.
    Whether that's the precise solution or not, I suspect you'd be better off asking in the Chrome forums then here. The Windows Security popups are simply the method that Windows provides for 3rd-party apps or Microsoft's own as well; to display the messages they require in order to receive input the app requires, precisely to avoid the types of randomly displayed, unformatted popups that you had mentioned might be abused in an attempt to phish users.
    Rob
