Why am I being asked for a Passkey? How do I turn off passkeys?
2024-07-22T21:51:35+00:00
I was opted into this without my knowledge, or without understanding how it works.
I have a solid understanding of Windows, and the security around it. But I do not understand why I suddenly am being forced to use, and constantly asked about passkeys, when I have not opted into them or set them up.
If I don't understand why I am being forced to use these, or why they are required, none of the less savvy users will. This will likely result in Microsoft spending more on tech support due to people being locked out of their devices.
Scenario: I have deleted the passkeys from my settings, and now my Edge logins have a discrepancy, because they are demanding passkeys that no longer exist.
For some reason, Windows is not allowing me to delete my Microsoft Passkey, because now that is required to sign in to my computer. I already have a PIN, a password, a fingerprint, and my face to sign in to my computer.
Is the only option logging out of my Microsoft Account and making it a local account to opt out of passkeys?
Passkeys need to be explained better if they are going to be a requirement, it needs to be a more gentle introduction.
Rob Koch 26,160 Reputation points Volunteer Moderator
2024-07-23T03:59:03+00:00
You've been using a passkey to login to Windows since you enabled Windows Hello to perform Face, Fingerprint or PIN login methods, since they' re an integral part of that system. They simply weren't as visible in the past, since the Passkey Management and using them for 3rd-party apps or websites weren't yet supported.
As usual, the problem is there are many documents available covering these and some confusing differences between the Azure Business-based systems using something called Entra for authentication and the consumer version of these related to your Microsoft Personal account. I'll include documents from both here in case you are more technically interested but tell you which I'm providing.
The first is an overview for consumer accounts and should help you understand how crucial they are to Microsoft's future authentication systems intended to remove the need for passwords, so trying to escae them is utterly pointless.
New passkey support for Microsoft consumer accounts | Microsoft Security Blog
This next one has more technical detail and in the first sections describes in general how they work, while a later section is specific to the Microsoft implementation and shows how these functions relate to Windows Hello, the Edge browser and other similar portions of Windows. I wouldn't typically provide this to the average consumer, but it really makes their operation on Windows clear for those wanting to understand them more deeply.
WebAuthn APIs - Windows Security | Microsoft Learn
I think I'll stop there for the moment to make sure you want more iformation, since upon quick review, these two documents cover the basics, while there are many others that provide the How-to explanations for individual portions of passkey operation.
Rob
< EDIT > BTW, here's a FAQ document with some common questions about passkeys, the last of which is titled; How can I provide feedback about my experience with passkeys?
Passkeys frequently asked questions (FAQ) - Microsoft Support
If you click the question to view the answer, you'll find a link to the Windows Feedback where you can submit your comments directly to Microsoft. Anything you post in this forum will only be seen by those who browse here, while virtually no Microsoft employees ever do and so your posts here are only really seen by us volunteer or a few contract helpers.
quietman7 MVP Alumni 19,830 Reputation points Volunteer Moderator
2025-06-22T21:08:03+00:00
I appreciate your response. If a password and the multi-authentication code is not sufficient, what does a 'passkey' do?
Why doesn't Microsoft provide some easy-to-understand explanation of what a 'passkey' is and why it is different for every site?
I provided that information in a previous reply (page 11) but here are those and some more links by Microsoft with explanations.
Passkeys Authentication Across Platforms - How Passkeys Registration and Authentication Work Across Devices and Platforms
Quote
To combat such risks, phishing-resistant Passwordless authentication methods, including enhanced support for Microsoft Authenticator, have become critical.
Just for the record...Microsoft has long been a proponent of passwordless authentication for years so this is nothing new. Other industries have been moving in that direction too. .
In a nutshell...Passkeys are stored as secrets locally on a device and use a device's unlock mechanism such as Windows Hello biometrics (fingerprint or facial recognition) or PIN sign-In options to authenticate them before signing in. Passkeys can be used without the need for other sign-in challenges, making the authentication process faster and more convenient. A passkey is invisible, virtual and employ public-key cryptography (keypair concept: a private key and a public key). The passkey is purposely hidden from access inside the TPM (Trusted Platform Module).
TPM chip is an embedded crypto-processor in laptops and is designed to provide hardware-based, security-related functions (carry out cryptographic operations. The TPM is isolated from the main processor and functions as a vault (a lockbox for keys) so in the event of malware attack or breach, sensitive user data remains secure.
129 additional answers
    2025-04-05T08:30:39+00:00
    Passkeys are the replacement for the passwords we have been using since always. It's actually easier to use a passkey than to use a password, and passkeys are many times more secure than passwords.
    ^^ This statement contains a lot of nonsense. Passkeys are a public/private key implementation and are probably good for casual users. For more advanced users, I think not.
    A good random password in a password database (maybe 512+ characters) properly implemented with substantial unique salt on the server is actually quite a bit more difficult to brute force than a passkey.
    Passkeys allow anyone with your device to have access to everything(assuming it is unlocked and decrypted of course that is implied in "access")
    Passkeys or any strings based on biometrics are immutable and permanent, so when stolen (and they will be) you have no recourse. You will be catapulted into stolen identity hell and have to manually contact every single site using that passkey.
    They like to say passkeys are immune to phishing but this is not the case, as a session can be a perfectly good attack surface for a malicious actor. There is also this CVE which shows a simple vulnerability via BlueTooth and the potential for similar vulnerabilities in the future. https://mastersplinter.work/research/passkey/ If root access to a passkey store is obtained, the entire passkey store and all the accounts can be compromised, just like any other system. External MFA can be used to mitigate this, but it is being touted as an advantage that you don't need it, so in that case all the accounts are compromised.
    So this push to force everyone into passkeys is creating an unnecessary honeypot and people with good security practices would be better served with PASSWORDS.
    2025-04-05T09:17:36+00:00
    There are two major flaws with passkeys.
    One, they only have a single factor, two, people aren't aware of them.
    People will be forced to login against their will by police by shoving the phone in their face, and you can only contort for so long, people will forget where their passkeys are, they'll be synced to cloud services on platforms people don't trust, the cloud providers will shut down, you name it.
    Yes, granny and her bad passwords are a bigger problem than that, but don't for a moment suggest that this is going to replace 2FA and password managers. It only replaces passwords people have in their heads, and that's only an improvement when the odours they have in their heads are bad (which is often the case). Problem is, Microsoft seems to have misunderstood that part of the assignment and are now shoving it in my face even though I already manage my passwords.
    2025-04-05T14:54:27+00:00
    My offer to explain what a passkey is, how it works, and why it's the future is still on the table. If no one is interested, that's okay with me. It's only an offer. If someone wants to argue about it, they'll have to find someone who's interested in arguing with them. It won't be me.
