Is there a solution to fix my cursor lock when using Xbox game bar?
2024-07-17T00:07:24+00:00
So for a couple weeks (about 3 weeks now) anytime I use xbox gamebar on windows 11 to join a party to talk to some friends, my cursor lock on all applications would break making my mouse cursor go to another monitor when working on something or playing a game. This still happens when the application is fullscreen or borderless full screen. I confirmed it is the xbox gamebar as I have no other problems with cursor lock when I don't use the gamebar. All my updates, drivers, and apps are up to date and repaired/not broken. currently I'm using a app that will manually lock the cursor to a screen, but would rather not need to do so. Hopefully this is enough info, if not I can clarify more.
Windows for home | Windows 11 | Gaming
    2025-01-31T01:29:00+00:00
    I have indeed confirmed that this workaround does work, however the party starting experience is not quite as smooth as it is with GameBar.
    2025-02-16T18:44:01+00:00
    I have recently updated to 24H2 Windows 11, and for some reason the Game Bar now will properly capture my mouse cursor when playing Minecraft (Bedrock).
    Seems to be fixed for me?
    2025-02-16T18:44:42+00:00
