Bosd caused due to watchdog.sys
2024-07-31T13:10:23+00:00
I have been receiving the bosd by the watchdog.sys for 1 and half month. I am very frustrated right now. I don't know what to do. After getting bosd my computer does not restart it shows the black screen. After doing the force shutdown It opens when we open after 4 minutes. And when we put our password it quietly runs for 2-3 minutes and again blue screen error occurs. Pleaseeeeee someone tell me the solution.pleaseee. And when I scan the dump files using who crashed app it said it was a vedio related error and caused by file watchdog.sys. Pleaseeeeee
  1. DaveM121 934.5K Reputation points Independent Advisor
    2024-08-02T14:32:16+00:00
    Yes, that is correct, the system crashes should not survive resetting or re-installing Windows.
    2024-08-02T14:54:51+00:00
    Thankyou
    How much does it normally costs to fix GPU for this error?
  3. DaveM121 934.5K Reputation points Independent Advisor
    2024-08-02T14:58:40+00:00
    There is no usual cost, that depends on the problem and also your location, I cannot quote you a price.
    2024-08-02T15:55:45+00:00
  5. DaveM121 934.5K Reputation points Independent Advisor
    2024-08-02T16:00:12+00:00
    All those new minidump files also list the Nvidia drivers as the cause of those new crashes.
