Bosd caused due to watchdog.sys
2024-07-31T13:10:23+00:00
I have been receiving the bosd by the watchdog.sys for 1 and half month. I am very frustrated right now. I don't know what to do. After getting bosd my computer does not restart it shows the black screen. After doing the force shutdown It opens when we open after 4 minutes. And when we put our password it quietly runs for 2-3 minutes and again blue screen error occurs. Pleaseeeeee someone tell me the solution.pleaseee. And when I scan the dump files using who crashed app it said it was a vedio related error and caused by file watchdog.sys. Pleaseeeeee
    2024-08-03T10:22:12+00:00
    Sir I just reset my pc and now I am having a problem that my WiFi option is not showing in windows 11 I tried a lot to fix this but none worked.
    (The below given image is by mistake please ignore that)
  2. DaveM121 934.5K Reputation points Independent Advisor
    2024-08-04T06:30:39+00:00
    With regards to the WiFi problem, go to the support page for your PC on the manufacturers website using another device that has an Internet connection to donwload the installer for the WiFi (WLAN) drivers, then transfer the installer to your PC and use the installer to re-install the WiFi drivers.
    2024-08-07T13:35:18+00:00
    Sir I reinstalled the windows yesterday but I have got the blue screen error 2 times after today . The new dump files are as follows:
    https://drive.google.com/file/d/1kibH-Qn1gPBjT48qqy92QawmQ47wiEnc/view?usp=sharing
    Could you tell me whether they are also caused by the Nvidia drivers???
