Hey again, sorry for late response, where can i find the results?
irql not less or equal
Hello, I had the BSOD Code that says "IRQL_NOT_LESS_OR_EQUAL" And i cant find a solution, i tried reinstall windows
i tried to buy new ram. i literally tried everything, can i get some help?
2024-08-20T11:56:47+00:00 -
DaveM121 935.1K Reputation points Independent Advisor2024-08-20T13:56:20+00:00 If no RAM errors were found, please follow the steps in number 2 above to enable Driver Verifier
2024-08-20T14:02:26+00:00 Can you give me instructions again please?
DaveM121 935.1K Reputation points Independent Advisor2024-08-20T14:30:47+00:00 To try to force Windows show any faulting drivers, the best option would be to turn on Driver Verifier, let your PC crash 3 times, then you must turn off Driver Verifier, and finally, upload any newly created minidump files
Before you run Driver Verifier, please create a new System Restore Point
https://answers.microsoft.com/en-us/windows/for...
Note, if you have any difficulty getting into Windows with Driver Verifier enabled:
Start your PC, just as Windows attempts to load (spinning dots), press and hold Power Button for 5 - 10 seconds to perform a Hard Shut Down
Do this twice
On the third start Windows will boot into the Recovery Environment and from there you can access System Repair, Safe Mode, Command Prompt... etc.
Go to Troubleshoot - Advanced Option - Startup Settings and click Restart
Upon restart, press 4 to enter Safe Mode
Open Command Prompt as Administrator and run these two commands, then restart your PC.
verifier /reset
verifier /bootmode resetonbootfail
