irql not less or equal
2024-08-20T07:57:30+00:00
Hello, I had the BSOD Code that says "IRQL_NOT_LESS_OR_EQUAL" And i cant find a solution, i tried reinstall windows
i tried to buy new ram. i literally tried everything, can i get some help?
  1. DaveM121 935.1K Reputation points Independent Advisor
    2024-08-20T08:28:15+00:00
    Hi, I am Dave, I will help you with this.
    Please check to see if your PC is producing any minidump files, I will check those to see if they provide any insight into a potential cause of the system crashes.
    Open Windows File Explorer.
    Navigate to C:\Windows\Minidump
    Copy any minidump files onto your Desktop, then zip those up.
    Upload the zip file to the Cloud (OneDrive, DropBox... etc.), then choose to share those and get a share link.
    Then post the link here to the zip file, so we can take a look for you.
    2024-08-20T08:35:16+00:00
    Is it okay if i do a google drive link?
  3. DaveM121 935.1K Reputation points Independent Advisor
    2024-08-20T08:38:19+00:00
    Yes, I can donwload from any cloud service you can upload the files to.
    2024-08-20T08:39:47+00:00
    Anyway, here it goes the google drive link, if its not good please let me know.
    https://drive.google.com/file/d/1PpwAraLDnAhzbqE3X9Qh0gSVCRSpWty6/view?usp=sharing
  5. DaveM121 935.1K Reputation points Independent Advisor
    2024-08-20T08:44:01+00:00
    Your minidump files just indicate RAM corruption as the cause of those crashes.
    1
    Seeing as the BSOD's have survived re-installing Windows, the best option is to download the widely available free utility MemTest86, then run a full 4 pass scan with that to test your RAM for physical errors
    2
    If no RAM errors are found, to try to force Windows 10 show any faulting drivers, the best option would be to turn on Driver Verifier, let your PC crash 3 times, then you must turn off Driver Verifier, and finally, upload any newly created minidump files
    Before you run Driver Verifier, please create a new System Restore Point
    https://answers.microsoft.com/en-us/windows/for...
    Note, if you have any difficulty getting into Windows with Driver Verifier enabled:
    Start your PC, just as Windows attempts to load (spinning dots), press and hold Power Button for 5 - 10 seconds to perform a Hard Shut Down
    Do this twice
    On the third start Windows will boot into the Recovery Environment and from there you can access System Repair, Safe Mode, Command Prompt... etc.
    Go to Troubleshoot - Advanced Option - Startup Settings and click Restart
    Upon restart, press 4 to enter Safe Mode
    Open Command Prompt as Administrator and run these two commands, then restart your PC.
    verifier /reset
    verifier /bootmode resetonbootfail
