I have successfully opened it.
Occasional BSODs on a newly built gaming PC. Need help solving the issue.
I have been getting occasional BSODs on a newly built PC, with the computer slowing down and losing fps before crashing. Normally, the computer instantly restarts after crashing, but the past two times it has crashed, it remained on the BSOD screen, allowing me to see the stop code. The first was DRIVER IQRL NOT LESS OR EQUAL, and the second was DPC WATCHDOG VIOLATION. I have run memtest86+ on my computer for over 7 hours and it passed 9 times without any errors. There is also nothing in my C:\Windows\Minidump folder, which I checked after the most recent crash.
2024-08-11T03:52:05+00:00 -
Jonathan Deives 81,630 Reputation points Independent Advisor2024-08-11T03:59:08+00:00 Zip the minidump file, upload it to Onedrive or Google Drive and send the link here so I can analyze it.
2024-08-11T04:03:52+00:00 -
2024-08-11T19:07:26+00:00 -
Jonathan Deives 81,630 Reputation points Independent Advisor2024-08-11T23:26:29+00:00 The minidump indicates that it is "amdgpio3.sys", which would be the AMD chipset that is causing the crashes.
Go to the motherboard manufacturer's website and download the chipset drivers.
