Occasional BSODs on a newly built gaming PC. Need help solving the issue.
2024-08-10T21:09:52+00:00
I have been getting occasional BSODs on a newly built PC, with the computer slowing down and losing fps before crashing. Normally, the computer instantly restarts after crashing, but the past two times it has crashed, it remained on the BSOD screen, allowing me to see the stop code. The first was DRIVER IQRL NOT LESS OR EQUAL, and the second was DPC WATCHDOG VIOLATION. I have run memtest86+ on my computer for over 7 hours and it passed 9 times without any errors. There is also nothing in my C:\Windows\Minidump folder, which I checked after the most recent crash.
    2024-08-11T23:57:34+00:00
    Alright, I will try this.
  2. Jonathan Deives 81,630 Reputation points Independent Advisor
    2024-08-12T00:00:01+00:00
    I will await your reply
    2024-08-12T01:05:18+00:00
    I am a bit confused by this. For reference, my computer's CPU is the AMD Ryzen 5 7600X, the GPU is the AMD Radeon RX 6750 XT, and the motherboard is ASRock B650M Pro RS WiFi. Do I have download drivers from the ASRock website?
  4. Jonathan Deives 81,630 Reputation points Independent Advisor
    2024-08-12T01:18:06+00:00
    Yes, drivers must be downloaded from the ASRock website.
    2024-08-12T01:59:29+00:00
    There is nothing on the ASRock drivers page that is labelled as AMD, AM5, or chipset. Instead, when I try to find these drivers, I only see results from the AMD website where the chipset driver downloads are there. Should I download them from there?
