Also having this same issue
How do I keep my mouse from leaving the window on FPS games?
So, when I'm playing any FPS games (or games that use the mouse to track the game environment), my mouse cursor goes invisible. However, instead of being locked to the center of the screen, it moves around freely, to the point where i have accidently minimized or closed out of my game. Also worth mentioning, this is on a laptop, not a multiple screen PC.
Any help with this problem would be greatly appreciated, as I've exhausted my sources of research and none of them helped.
2024-11-14T04:18:40+00:00 -
2024-11-14T16:37:05+00:00 I am also now having this problem. I think it was with Nvidias latest driver update that caused it.
2024-11-14T20:14:48+00:00 I am having this issue, it's either windows 11 update or like you said nvidias, have u tried uninstalling it? It's driving me crazy and im soo glad i have found this thread so now i know it's an update.
2024-11-16T01:59:26+00:00 I got another windows update and a NVidia update as well! Happened a couple days ago! I'm not having the problem anymore, I'm not sure what the cause is.
2024-11-16T03:13:15+00:00 I recently started to get this issue. I've been using DMT, which provides an exclusive screen lock. It helps to some extent, it's more of a "band-aid" it doesn't fix the core problem which is the cursor still moves freely behind the game window, causing confusion, especially when opening maps or using selection wheels in-game. My cursor ends up in a random part of the screen instead of being auto centered like before.
I have been trying to find a solution but have had no luck. please if anyone finds a solution post it up
