How do I keep my mouse from leaving the window on FPS games?
2024-08-10T15:11:05+00:00
So, when I'm playing any FPS games (or games that use the mouse to track the game environment), my mouse cursor goes invisible. However, instead of being locked to the center of the screen, it moves around freely, to the point where i have accidently minimized or closed out of my game. Also worth mentioning, this is on a laptop, not a multiple screen PC.
Any help with this problem would be greatly appreciated, as I've exhausted my sources of research and none of them helped.
  1. Quinn.HP 9,755 Reputation points Independent Advisor
    2024-08-10T17:30:02+00:00
    If you're comfortable, you can temporarily disable your antivirus or firewall to download the file, then re-enable it immediately. SourceForge is generally a safe source to download, but as an extra precaution, you could also scan the downloaded file.
    2024-08-10T18:40:10+00:00
    Unfortunately, this did not solve the issue.
  3. Quinn.HP 9,755 Reputation points Independent Advisor
    2024-08-11T02:06:53+00:00
    Just to clarify, have you tried pressing your hotkey while in the game?
    2024-08-11T11:46:34+00:00
    Yes, I have.
  5. Quinn.HP 9,755 Reputation points Independent Advisor
    2024-08-11T13:43:03+00:00
    If that didn't work. Try updating your graphics drivers. You can typically do this through your computer's Device Manager or by visiting the website of your graphics card manufacturer (like NVIDIA or AMD) to download the latest drivers. Feel free to reply if you need further assistance.
