Problem after update
2024-08-18T11:23:41+00:00
After an update on 15 August (I think), one of the users (admin) gets a recurring screen (http://ventre-a-pattes.net/bug.jpg) and cannot work. Two other accounts (one admin, one not) do not have the problem, a third one (not admin) does too. I tried to uninstall all recent items, ran update again, nothing works. Thanks for any suggestion.
    2024-08-19T08:53:57+00:00
    No, and no need to, it reappears every few seconds for a very limited time.
    2024-08-19T10:16:44+00:00
    Also, I have tried to end the processes running in the defective account and not in the working one. Did not work, but I most certainly did not find all of them.
  3. Emmanuel Santana 40,200 Reputation points Independent Advisor
    2024-08-19T17:23:09+00:00
    Thank you for reaching out again. You might be able to fix this using Windows recovery mode.
    From the login screen, press Shift while selecting Restart. If needed, repeatedly force a shutdown during boot to trigger Automatic Repair.
    Navigate to Troubleshoot > Advanced Options > Command Prompt.
    Enter the following commands:
    dism /online /cleanup-image /restorehealth
    sfc /scannow
    After running the commands, close the Command Prompt and restart your computer.
    2024-08-19T20:50:43+00:00
    /cleanup-image unknown (Win 11)
    only Cleanup's are
    /Cleanup-Wim and /Cleanup-Mountpoints
  5. Emmanuel Santana 40,200 Reputation points Independent Advisor
    2024-08-20T02:24:44+00:00
    I think that's an error directly with the command, try using this: dism /online /cleanup-image /restorehealth
