Copilot voice mode keeps saying Sorry, we’ll have to talk later
2024-10-05T12:27:58+00:00
I'm a pro user. Ive tried to use copilot voice. However it keeps saying
Why does it happen
**Windows / Windows Copilot / feature **
    2024-10-18T06:41:37+00:00
    Também estou com o problema, gostaria de saber como funciona a comunicação do Windows com o telefone... acredito ter 1 rootkit por aqui e general...
    2024-10-18T11:41:42+00:00
    When the Microsoft 365 Admin Center shows a green checkmark, it typically means that the voice module problem has been fixed. If you are in a region where Voice Search is not accessible yet, you can use the old Voice Search feature in the Microsoft Edge Copilot button until the new Voice Mode becomes globally accessible. https://status.cloud.microsoft/
    2024-10-18T17:46:12+00:00
    me too
    2024-10-18T17:56:17+00:00
    Thats true the Copilot Voice search is not available in EU that is an update I can confirm from my end thats what the Agent have told me so that is the reason for the messages in your regions as well so relax :)
    2024-10-18T23:42:26+00:00
    Why does it happen
    It's on their side and the Techs are working on it, I spoke to them today.
    My Android and my Windows Copilot Pro does the same thing since around the 9th.
    I can use Copilot pro using voice through Edge. Using it for a workaround.
    Make sure you use it in edge the blue Copilot icon.
    Only thing is having to push the mic button every time.
