How do I fix a stretched screen?
2024-09-12T14:17:28+00:00
Hello, Whenever I start my laptop, the windows boot screen and progressive ring are stretched. I've tried updating and rolling back drivers, I've used CMD, and more. I installed Windows 11 about a month ago on unsupported hardware.
NOTE TO ALL OF YOU. UPDATING DOES NOT FIX IT
Someone told me to go back to Windows 10, I did. Not resolved.
  1. DaveM121 933.8K Reputation points Independent Advisor
    2024-09-12T15:41:47+00:00
    That Intel app will still run without the update service running.
    2024-09-12T15:47:10+00:00
    tried running and it told me to download this and this happened
  3. DaveM121 933.8K Reputation points Independent Advisor
    2024-09-12T15:52:07+00:00
    That is the DotNet Framework 4.8, it is not compatible with your 9 year old version of Windows, really the only option will be to install a more up to data version of Windows 10 to get your system stable.
    2024-09-12T15:56:13+00:00
    fine. gimme 15 mins
  5. DaveM121 933.8K Reputation points Independent Advisor
    2024-09-12T15:59:29+00:00
    Okay.
