is that computer a desktop or laptop,.?
Changed to the one displayed on this answer 1920 X 1080
to verify. if fix the problem. if not reverse it
to 1366 X 768
Did you mean: What's the default resolution for windows 10 screen
1920×1080
The default resolution on your primary display (laptop, in this case) will be applied
to all displays. It's typically 1920×1080. If you want a different resolution
for one of the additional displays, click on its rectangle.
A dropdown menu will appear. Nov 9, 2023
