How do I fix a stretched screen?
2024-09-12T14:17:28+00:00
Hello, Whenever I start my laptop, the windows boot screen and progressive ring are stretched. I've tried updating and rolling back drivers, I've used CMD, and more. I installed Windows 11 about a month ago on unsupported hardware.
NOTE TO ALL OF YOU. UPDATING DOES NOT FIX IT
Someone told me to go back to Windows 10, I did. Not resolved.
    2024-09-14T23:24:55+00:00
    i already did...
    2024-09-14T23:27:11+00:00
    Just now I've got version 20H2. I can send an updated screenshot Monday.
  3. DaveM121 933.8K Reputation points Independent Advisor
    2024-09-15T06:12:06+00:00
    You have Windows installed in UEFI Mode, if you switch to Legacy BIOS and format the drive as MBR, that may resolve the problem.
    2024-09-16T12:47:14+00:00
    ms info NEW
  5. DaveM121 933.8K Reputation points Independent Advisor
    2024-09-16T12:50:05+00:00
    That screenshot indicates you have upgraded your version of Windows, but that will not solve the stretched screen that appears before Windows starts, because it is BIOS that controls that screen, if there is no BIOS update available, you probably cannot fix that.
