The "4657" event ID should be created if the proxy setting reverted to 0 and you enabled auditing correctly.
I'd like to see the output of the Auditing tab.
Also, post the output of this command:
auditpol /set /subcategory:"Registry" /success:enable
(run it from admin Command Prompt.)
You ran that command earlier, but the output/screenshot wasn't posted.
