Proxy Settings Per User - problems
2024-09-30T16:55:42+00:00
Can anyone advise me how to stop the 'Proxy settings per user' in the Registry under 'Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\CurrentVersion\Internet Settings' from returning to Zero everytime I reboot the PC when I want it to stay set at 1. I am not an expert on PC but can sort things out if I'm given clear instructions. I am running the latest up to date version of Windows 10. Many thanks in advance.
    2024-10-01T11:12:14+00:00
    Appologies Ramesh, I thought it showed at zero. I obviously had reset it when I took the picture which is what I have to do everytime I open up the PC!
  2. Ramesh Srinivasan 87,865 Reputation points Independent Advisor
    2024-10-01T09:14:47+00:00
    Hi John,
    In the screenshot, I see the value data of "ProxySettingsPerUser" is set to 1, not 0.
    2024-10-01T08:27:47+00:00
    Thanks for that Romesh but I only have a standard windows 10 please see screen shot where as you can see it has reverted once more to zero and I need it to be 1. Thank for your help though :)
  4. Ramesh Srinivasan 87,865 Reputation points Independent Advisor
    2024-09-30T17:35:27+00:00
    Hi John, This is Ramesh.
    If you're using Windows 10 Pro or higher, you can configure the setting using the local group policy editor.
    Launch "gpedit.msc" and go to the following branch:
    Computer Configuration → Administrative Templates → Windows Components → Internet Explorer.
    Double-click "Make proxy settings per-machine (rather than per-user)" and configure it accordingly.
