I plugged in the Ethernet and I’m still having the same issue
Why is my wifi adapter stuck on identifying
A couple days ago I shutdown my PC, when I turned it back on, it would connect to the internet but it won’t provide internet access displaying “no internet, secured” on the wifi tab in the bottom right. In control panel, network connections won’t stop saying “identifying”. I have tried a network reset and it did not work. I tried to run the troubleshooter and it will not work because after the network reset windows started saying that I had not activated it, and I can activate it without wifi… I clicked the get help tab in settings and half the time it says I’m connected and didn’t find any issues the other half it says can’t connect to the internet with manually assigned ip address, but I have everything set to automatic. All other devices connected to the wifi work and my isp says that there are no issues from their end.
Windows for home | Windows 11 | Internet and connectivity
2024-10-30T16:28:03+00:00 -
Jonathan Deives 81,965 Reputation points Independent Advisor2024-10-30T16:34:44+00:00 Click on start menu and type msinfo32
Open System Information
Take a screenshot and post it here please
2024-10-30T16:36:54+00:00 I plugged the Ethernet cable in and I’m still having the same problem. I tried redoing all the prompts in the command prompt and when I did ipconfig /release and ipconfig /renew it said that the RPC server is unavailable.
2024-10-30T16:38:47+00:00 Do you want a screen shot of the system summary or of all the hardware resources, components, and software environment?
2024-10-30T16:41:03+00:00 ![](https://learn-attachment.microsoft.com/api/attachments/49fea544-bd2a-42a0-b18a-8d8876ca3f57?platform=QnAIs this what your looking for for a screenshot?
