Ok.
If you want the minidump to be analyzed, feel free to share it.
If you have any questions, don't hesitate to ask. Click on the "Reply" button below my reply.
changed gpu,ram.motherboard and installed clean windows 11 but still no fix
crashdumps provided below before and while using verifier
before using verifier
while using verifier Minidump2.rar
Ok.
it kept crashing when i was formatting my usb prolly will happen when im installing windows as well
here are the dump files
Of the minidumps you shared, one mentions only a generic system file, and the other mentions a driver related to the AMD processor.
You can create the installation media using another computer running Windows.
Is this possible for you?
If your computer crashes during the clean install, you can be sure that the problem is with the hardware.
the best way to fix the general system file is clean installing right?
ill give a shot at creating using another computer
so i clean installed windows and got all the drivers downloaded looks kinda promising no crashes yet its been like 30 mins
ill let you know if anythings up
