Keep Getting Ntkrnlmp.exe frequent BSOD Help
2024-09-25T13:53:46+00:00
changed gpu,ram.motherboard and installed clean windows 11 but still no fix
crashdumps provided below before and while using verifier
before using verifier
Minidump1.rar
while using verifier Minidump2.rar
    2024-10-03T01:44:40+00:00
    so david ive swapped my cpu to a 5600x it looks promising no crashes for far its been more than 12 hours
    no errors on occt but the only problem i have is i clean installed windows again after installing the new cpu just in case
    whenever i remove the frequently used app from the recommended section it just appears again when i open start any fixes?
    2024-10-04T16:46:58+00:00
    hello?
