WaaSMedicService problem -- Issue found by :WinRETargetingPlugin
2024-10-11T21:01:47+00:00
My PC crashed frequently due to a faulty memory stick. When I used a new memory stick, the problem didn't occurred anymore. Unfortunately, the crash also occurred during the windows update after the in-place upgrade. Until now, I have been unable to download and install two important updates -- the latest cumulative update and the update from August. (Two error codes (0x80070643 and 0x800f0805) appeared alternately)
I just tried Windows update troubleshooter and get a diagnosis --
WaaSMedicService
Problem with BITS service : The requested service has already been started. More help is available by typing NET HELPMSG 2182
Also, I've tried to perform the second in-place upgrade but ended in failure, an error occurred during the process(More details at https://answers.microsoft.com/en-us/windows/forum/windows_10-update/error-in-downloading-windows-10-cumulative/6ec330e1-c849-4b83-97db-286974f4290a?messageId=84f7d351-326d-49d5-8c7a-d154d5a69c89)
I hope all problems can be fixed without losing any data, please help me with a targeted solution as much as possible! Thanks!
  1. Ramesh 181.8K Reputation points Volunteer Moderator
    2024-10-14T05:54:27+00:00
    Here are the latest setup logs --
    https://1drv.ms/u/c/368eb4378be4cf9d/EXchzIpM7tlJviXexzHl2BsBxWX6P-DCQE1oIYSXlS1OaA?e=s1dmjL
    Please copy these lines to the clipboard.
    Start::
    CreateRestorePoint:
    S3 CisUtMonitor; C:\WINDOWS\system32\DRIVERS\CisUtMonitor.sys [53312 2023-01-15] (Texode Technologies, LLC -> CrystalIdea Software)
    S3 NvStUSB; C:\WINDOWS\System32\drivers\nvstusb.sys [435416 2014-07-02] (NVIDIA Corporation -> NVIDIA Corporation)
    StartBatch: sc qc tap0901
    reg save HKLM\SYSTEM\CurrentControlSet\Services\NvStUSB c:\NvStUSB.dat
    reg save HKLM\SYSTEM\CurrentControlSet\Services\tap0901 c:\tap0901.dat
    sc delete tap0901
    dism /online /get-drivers /format:list
    EndBatch:
    File: C:\WINDOWS\System32\drivers\tap0901.sys
    End::
    Open the Farbar tool, and click Fix.
    Upload fixlog.txt.
    2024-10-14T12:57:09+00:00
    Start::
    CreateRestorePoint:
    sc delete tap0901
    EndBatch:
    End::
    Upload fixlog.txt.
    Here is the fixlog.txt --
    https://1drv.ms/t/c/368eb4378be4cf9d/EbRbbbvZ92JImzvTbT9LdcgB-2Mp6XIFTfIsjtyUopgcYg?e=ZW6NGF
  3. Ramesh 181.8K Reputation points Volunteer Moderator
    2024-10-14T13:11:29+00:00
    Please see if you can uninstall these two driver packages using Driver Store Explorer.
    The first one is very outdated, it's from 2010.
    Published Name : oem0.inf
    Original File Name : heci.inf
    Inbox : No
    Class Name : System
    Provider Name : Intel
    Date : 10/19/2010
    Version : 7.0.0.1144
    Published Name : oem1.inf
    Original File Name : oemvista.inf
    Inbox : No
    Class Name : Net
    Provider Name : TAP-Windows Provider V9
    Date : 4/21/2016
    Version : 9.0.0.21
    If nothing helps, you may create an image-based backup of the OS partition to an external drive and consider clean installing 22H2 using USB.
    2024-10-14T14:08:23+00:00
    Inbox : No
    Class Name : System
    Date : 10/19/2010
    Inbox : No
    Class Name : Net
    Date : 4/21/2016
    Version : 9.0.0.21
    I notice that heci.inf is system driver, It shows 'error removing heci.inf when I try to remove it. You told me not to remove the system driver before, why are you telling me to remove it now?
    If you can't help me solve the problem that prevented me from completing the in-place upgrade successfully, could you help me solve the problem about Windows 10 cumulative update without losing any data(please help me with a targeted solution as much as possible)?
    (I just found all other updates can be successfully installed, but still error in downloading and installing cumulative update)
  5. Ramesh 181.8K Reputation points Volunteer Moderator
    2024-10-14T14:20:04+00:00
    I suggest removing System drivers as a last resort. The previous output shows the driver is very outdated (10/19/2010), which can cause problems (especially the error code 0xc1900101) during the setup. Removing drivers is a trial-and-error solution because the logs didn't indicate which driver was at fault.
    To fix the CBS error code 0x800f0805 surgically, you may try Sysnative forum, the best forum for such WU/CBS/CSI issues.
