WaaSMedicService problem -- Issue found by :WinRETargetingPlugin
2024-10-11T21:01:47+00:00
My PC crashed frequently due to a faulty memory stick. When I used a new memory stick, the problem didn't occurred anymore. Unfortunately, the crash also occurred during the windows update after the in-place upgrade. Until now, I have been unable to download and install two important updates -- the latest cumulative update and the update from August. (Two error codes (0x80070643 and 0x800f0805) appeared alternately)
I just tried Windows update troubleshooter and get a diagnosis --
WaaSMedicService
Problem with BITS service : The requested service has already been started. More help is available by typing NET HELPMSG 2182
Also, I've tried to perform the second in-place upgrade but ended in failure, an error occurred during the process(More details at https://answers.microsoft.com/en-us/windows/forum/windows_10-update/error-in-downloading-windows-10-cumulative/6ec330e1-c849-4b83-97db-286974f4290a?messageId=84f7d351-326d-49d5-8c7a-d154d5a69c89)
I hope all problems can be fixed without losing any data, please help me with a targeted solution as much as possible! Thanks!
  1. Ramesh 181.8K Reputation points Volunteer Moderator
    2024-10-13T15:29:04+00:00
    A System Restore Point was created, and the drivers were removed.
    (I hope you've already backed up the registry using RegBak.)
    Please restart the system and re-run the 22H2 setup.
    Note:
    There is another outdated driver that I missed deleting.
    • NvStUSB; C:\WINDOWS\System32\drivers\nvstusb.sys [435416 2014-07-02]
    Let's rerun the setup and decide on that.
    2024-10-13T15:36:42+00:00
    The current sharing link was created about half an hour ago, but its validity is unstable. I originally intended to use it to temporarily transfer the file to my mobile device and re-upload it to OneDrive, but the upload function of the browser on the mobile device just had some problems. . .
    2024-10-13T15:42:29+00:00
    Do you mean re-run the media creation tool and share the setup log?
  4. Ramesh 181.8K Reputation points Volunteer Moderator
    2024-10-13T15:51:53+00:00
    Yes, I meant the setup logs (Panther and Rollback).
    2024-10-13T18:28:21+00:00
    Here are the latest setup logs --
    https://1drv.ms/u/c/368eb4378be4cf9d/EXchzIpM7tlJviXexzHl2BsBxWX6P-DCQE1oIYSXlS1OaA?e=s1dmjL
