VPN connection problem after Windows 11 Pro 24H2 update
2024-10-03T15:29:18+00:00
Yesterday I installed some updates (24H2) on a Windows 11 Pro OS.
After that the connection to my work VPN stopped connecting correctly.
Did anyone have the same issue?
How can I solve?
Tnx
Windows for home | Windows 11 | Internet and connectivity
    2024-10-07T11:33:01+00:00
    Hi Sumit
    I confirm that downgrading the Windows 11 version to the one before 24H2, the VPN works correctly.
    In the meanwhile, also other users in my company had the same problem.
    Now I hope that Microsoft will soon release a fix...
    HTH
    Thank you
  2. SD - IA 179.6K Reputation points Independent Advisor
    2024-10-07T12:31:24+00:00
    Thank you Nick.
    Please remain on 23H2 in the meantime - a new update would be available tomorrow, hopefully it might have the fix.
    2024-10-07T19:48:30+00:00
    checkpoint endpoint connect vpn client fails after the upgrade. tried multiple versions had to revert back to prev version of windows. Also seems like dell peripheral manager has issues
    2024-10-08T12:55:36+00:00
    I have the same issue Checkpoint VPN client
    2024-10-08T13:03:40+00:00
    Settings => System => Recovery => Go back
