Kernal Power 41 error & Critical Process Died
2024-11-25T17:52:36+00:00
Hi, Recently built a new PC. I've been getting the Kernal Power 41 error and Critical Process Died.
Now when I login to windows and I move my mouse or click onto something it freezes and gives me a BSoD. However if I wait a few seconds without going into the apps striaght away it seems to work fine.
I have double checked all cables and they seem to be on tight. I have ran OCCT stress test on all components and they pass. When I game it runs fine.
I have done a clean install of windows twice. All drivers are up to date, I've ran chkdsk /r and other diagonstics. Nothing so far.
CPU is Ryzen 7 7800x3d
Motherboard b650 aorus elite ax
GPU 4080 Super
G. skill ram 32gb 6000mhz 30cl - not running on amd expo
850w corsair psu.
Any Idea why this may be happening?
    2024-11-26T13:12:37+00:00
    is there an alternative method than having 2 m.2s in? my mobo only has one m.2 slot
  2. DaveM121 936.3K Reputation points Independent Advisor
    2024-11-26T13:15:33+00:00
    Connect the old M.2 drive to your PC, boot up from your Windows USB and at the start of the installation process, delete all partitions on the drive.
    Then remove the old M.2 from your PC.
    2024-11-26T13:26:57+00:00
    Hi, managed to add an m.2 in mobo i cant wipe the 100mb and 651 mb options. I managed to do it for the middle box
  4. DaveM121 936.3K Reputation points Independent Advisor
    2024-11-26T13:29:27+00:00
    In that case, use the bootable USB method to wipe the drive by deleting those partitions.
    2024-11-26T13:53:50+00:00
    so the new m.2 is set up now. Ive checked windows events and theres still critical kernal power 41 although ive not had any freezes or crashes so far..
