Hi, everything good so far. Only minor issue is if I restart my pc it would just go to a black screen and the dram light would be on the motherboard. It happens sometimes not always. But I am able to shut down the pc reguaraly and boot it back up. Theres no critical errors on event viewer. No bSOD either
Kernal Power 41 error & Critical Process Died
Hi, Recently built a new PC. I've been getting the Kernal Power 41 error and Critical Process Died.
Now when I login to windows and I move my mouse or click onto something it freezes and gives me a BSoD. However if I wait a few seconds without going into the apps striaght away it seems to work fine.
I have double checked all cables and they seem to be on tight. I have ran OCCT stress test on all components and they pass. When I game it runs fine.
I have done a clean install of windows twice. All drivers are up to date, I've ran chkdsk /r and other diagonstics. Nothing so far.
CPU is Ryzen 7 7800x3d
Motherboard b650 aorus elite ax
GPU 4080 Super
G. skill ram 32gb 6000mhz 30cl - not running on amd expo
850w corsair psu.
Any Idea why this may be happening?
2024-12-01T17:34:37+00:00
