antivirus not working
2024-11-12T13:24:57+00:00
antivirus not working, I see lots of instances of this on YouTube self-fix. I've tried a few - with no improvement?
lets face it IT support is non-existent from Windows
any of you have any tips?
Ramesh 182K Reputation points Volunteer Moderator
2024-11-13T11:55:47+00:00
On unsupported systems, you may use one of the methods in this link to run setup. https://www.elevenforum.com/t/bypass-windows-11-system-requirements.1989/
The following disclaimer applies if Windows 11 is installed on a device that doesn't meet the minimum system requirements:
This PC doesn't meet the minimum system requirements for running Windows 11 - these requirements help ensure a more reliable and higher quality experience. Installing Windows 11 on this PC is not recommended and may result in compatibility issues. If you proceed with installing Windows 11, your PC will no longer be supported and won't be entitled to receive updates. Damages to your PC due to lack of compatibility aren't covered under the manufacturer warranty. By selecting Accept, you are acknowledging that you read and understand this statement.
Src: Installing Windows 11 on devices that don't meet minimum system requirements - Microsoft Support: https://support.microsoft.com/en-us/windows/installing-windows-11-on-devices-that-don-t-meet-minimum-system-requirements-0b2dc4a2-5933-4ad4-9c09-ef0a331518f1
42 additional answers
    2024-11-12T17:28:13+00:00
    Farbar Recovery Scan Tool 64-bit (FRST64.exe)
    this is taking some time - hopefully, I won't miss any stages out - here if you put too many up?
    2024-11-12T17:36:29+00:00
    In addition to the Farbar logs, please download defender_diag.bat (direct download link - zipped).
    https://gist.github.com/winhelponline/f01861081...
    Right-click on the downloaded file, click Properties, select "Unblock" (if it exits), and OK. Then, run the batch file as an administrator.
    The Batch file queries Defender-related settings/Policies and outputs the results to a log file named defender.log in your %temp% folder. Upload this log to your OneDrive and share the link here.
    the  Farbar Recovery Scan Tool 64-bit (FRST64.exe) scan has saved a text file BUT WHERE!
    it's not obvious, I've looked in downloads and program files
  3. Ramesh Srinivasan 88,105 Reputation points Independent Advisor
    2024-11-12T17:44:21+00:00
    I understand the troubleshooting didn't help you resolve this issue. I'm releasing this question so another advisor can help you.
    Thanks.
    2024-11-12T17:52:57+00:00
    I haven't finished yet - this takes ages!
    THE SCAN LOGS
    FRST.zip
    Addition.zip
    I have Defender logs too here, I will zip and share them here.
    defender.zip
