antivirus not working
2024-11-12T13:24:57+00:00
antivirus not working, I see lots of instances of this on YouTube self-fix. I've tried a few - with no improvement?
lets face it IT support is non-existent from Windows
any of you have any tips?
2024-11-13T11:55:47+00:00
On unsupported systems, you may use one of the methods in this link to run setup. https://www.elevenforum.com/t/bypass-windows-11-system-requirements.1989/
The following disclaimer applies if Windows 11 is installed on a device that doesn't meet the minimum system requirements:
This PC doesn't meet the minimum system requirements for running Windows 11 - these requirements help ensure a more reliable and higher quality experience. Installing Windows 11 on this PC is not recommended and may result in compatibility issues. If you proceed with installing Windows 11, your PC will no longer be supported and won't be entitled to receive updates. Damages to your PC due to lack of compatibility aren't covered under the manufacturer warranty. By selecting Accept, you are acknowledging that you read and understand this statement.
Src: Installing Windows 11 on devices that don't meet minimum system requirements - Microsoft Support: https://support.microsoft.com/en-us/windows/installing-windows-11-on-devices-that-don-t-meet-minimum-system-requirements-0b2dc4a2-5933-4ad4-9c09-ef0a331518f1
42 additional answers
    2024-11-12T13:47:19+00:00
    What anti-virus are you using? What version of Windows 11 are you using and do you keep it up to date?
    Look at your Other Updates and the Windows Malicious Software Removal Tool.
    Check out Privacy & security>Windows Security and see what is showing.
    IT Definition - What is Information Technology?
  2. Ramesh Srinivasan 88,100 Reputation points Independent Advisor
    2024-11-12T13:56:33+00:00
    Hi Nigelblue, I'm Ramesh, here to answer your query at the Microsoft Community.
    Please mention the problem you're facing with the antivirus program. Are you referring to Microsoft Defender Antivirus?
    If you're receiving any errors, please mention them here. Also, mention the steps you've tried so far.
    2024-11-12T14:20:23+00:00
    Updates are
    Windows 11
    Updates are all working, if I can paste 2 photos you might see better?
    2024-11-12T14:21:02+00:00
    Windows Malicious Software Removal Tool. might be good?
