update repair installation stuck on 34%
2024-11-21T09:07:03+00:00
i ran the update troubleshooter but the settings got stuck so i opened it again and now its download from 0% again
it was stuck at 34% for an hour help pls
2024-12-06T10:44:20+00:00
It's the same (UDC) driver. But the INF number has changed since you rolled back the driver.
To uninstall the driver using PnpUtil, run:
From the admin Command Prompt, run:
  • md C:\Drivers
  • DISM /online /export-driver /destination:C:\Drivers
The above commands backup the drivers. After the above operation is complete, run the following command to completely uninstall the Lenovo UDC driver.
  • pnputil /delete-driver oem62.inf /uninstall /force
  • pnputil /delete-driver oem33.inf /uninstall /force
41 additional answers
    2024-12-06T09:48:02+00:00
    doing an driver rollback worked but after it the update installed 100% windows said "undoing changes made to your computer"
    2024-12-06T09:54:27+00:00
    The following batch file collects the setup logs and saves the zip file to your desktop.
    Download setuplogscollect.bat and run it.
    https://1drv.ms/u/s!AjVYLGw0OBWU4hhK-912luEn0-aq?e=9bWbra
    It outputs a SetupLogs.zip file on your desktop.
    Share the file on OneDrive and post the download link here.
    2024-12-06T10:34:52+00:00
    2024-12-07T04:50:45+00:00
    https://forums.lenovo.com/t5/Gaming-Laptops/need-help-regarding-windows-update/m-p/5349712?page=1#6495387
    the
    the lenovo help person has told me that the driver is safe to remove i will disable it till i update and then enable it after im done with updating
