update repair installation stuck on 34%
2024-11-21T09:07:03+00:00
i ran the update troubleshooter but the settings got stuck so i opened it again and now its download from 0% again
it was stuck at 34% for an hour help pls
2024-12-06T10:44:20+00:00
It's the same (UDC) driver. But the INF number has changed since you rolled back the driver.
To uninstall the driver using PnpUtil, run:
From the admin Command Prompt, run:
  • md C:\Drivers
  • DISM /online /export-driver /destination:C:\Drivers
The above commands backup the drivers. After the above operation is complete, run the following command to completely uninstall the Lenovo UDC driver.
  • pnputil /delete-driver oem62.inf /uninstall /force
  • pnputil /delete-driver oem33.inf /uninstall /force
41 additional answers
    2024-11-29T18:11:50+00:00
    Please share the following setup log file on OneDrive (or any other host) and post the link here:
    C:$WINDOWS.~BT\Sources\Panther\setupact.log
    Note: "C:$WINDOWS.~BT" is a hidden folder. To access it, press Win + R, type "C:$WINDOWS.~BT" and click OK.
    (How-To: Share OneDrive files and folders - Microsoft Support)
    https://support.microsoft.com/en-us/office/share-onedrive-files-and-folders-9fcc2f7d-de0c-4cec-93b0-a82024800c07
    OneDrive sharing options - screenshot: https://imgur.com/a/vZyxpY9
    2024-12-03T04:26:23+00:00
    hey sorry for the late reply but may i instead get help in how i can use an windows iso as source for an dism repair thank you
    2024-12-03T05:17:56+00:00
    Why do you want to run the DISM repair? Are you getting any errors?
    2024-12-04T03:24:52+00:00
    also of my windows files are corrupted im pretty sure and thats why im not able to update
    i tried the repair version but it also says update failed
    so i want to use dism and repair my files and then update
