update repair installation stuck on 34%
2024-11-21T09:07:03+00:00
i ran the update troubleshooter but the settings got stuck so i opened it again and now its download from 0% again
it was stuck at 34% for an hour help pls
2024-12-06T10:44:20+00:00
It's the same (UDC) driver. But the INF number has changed since you rolled back the driver.
To uninstall the driver using PnpUtil, run:
From the admin Command Prompt, run:
  • md C:\Drivers
  • DISM /online /export-driver /destination:C:\Drivers
The above commands backup the drivers. After the above operation is complete, run the following command to completely uninstall the Lenovo UDC driver.
  • pnputil /delete-driver oem62.inf /uninstall /force
  • pnputil /delete-driver oem33.inf /uninstall /force
41 additional answers
    2024-11-21T09:41:38+00:00
    Hi a31_091,
    I'm Christine, I'll be happy to assist you. I can see here that your Windows update is being stuck. No worries, I'll do my best to help you.
    May I know the version or build of Windows that you're running? (Please press Windows key+R and type winver and hit enter)
    Please follow the steps below:
    1. Windows Update Troubleshooter
    Windows 11
    Please Click Start menu and type Troubleshoot
    Hit Other troubleshooters
    And select Windows Update
    Finally, Run the troubleshooter
    1. Reset Windows update services:
    Please click start menu and type cmd, right click on it and choose run with admin
    Kindly copy and paste the command lines below and hit enter:
    net stop wuauserv
    net stop cryptSvc
    net stop bits
    net stop msiserver
    Ren C:\Windows\SoftwareDistribution SoftwareDistribution.old
    Ren C:\Windows\System32\catroot2 Catroot2.old
    net start wuauserv
    net start cryptSvc
    net start bits
    net start msiserver
    Please try to update again.
    Please let me know the result. I'll be happy to assist you all the way until it's resolved.
    Thank you,
    Christine L
    Independent Advisor
