Phone link error 256 with S22 Ultra
2024-11-20T07:36:00+00:00
I have had Phone link working for years with my Samsung Galaxy S22 ultra.
Recently, part of the functionality stopped working, specifically, the "open phone screen" part. I keep getting an error 256.
The phone is on Wifi, connected to a Ubiquiti NanoHD.
The PC is a desktop on 10 Gbps ethernet.
Both are in the same /24 subnet, using DHCP with IP reservations in the router.
The phone says it's connected to the PC. The PC says the phone is connected to it.
I can see the phone's text messages & photos on the PC.
I just can't open the phone screen on my PC, or show any app on my PC's screen.
Windows for home | Windows 10 | Connect Phone and PC
    2024-11-25T22:49:48+00:00
    i agree with this but for some reason phone link lags a bit when Im using the mirror screen mode in the past, this goes away with samsung flow even though both are supposedly connected via wifi? I heard that the phone link app not working properly had to do with some "windows app" being discontinued? I could be wrong but I still cant believe microsoft hasn't address this issue.
    2024-11-26T00:16:32+00:00
    Yes, they are both connected via Wifi.
    Phone Link/Link to windows has a setting to only connect through Wifi.
    I don't see that setting in Samsung flow. But it works fine with the phone in airplane mode (cell disabled, Wifi on).
    I have not noticed a performance/lag difference between the two apps. The screen sharing is snappy in both.
    2024-11-26T15:41:00+00:00
    Thank you all for reporting this issue. We are currently investigating this and will get back to you as soon as we have something to share. Thank you for your patience.
    Andrea, thank you for posting this update. Good to know it's on the radar.
    2024-11-26T16:35:53+00:00
    it's pretty wild, you have so many new users from apple. and youre biggest competition left was and is samsungs enviroment, sucks. not user friendly. and now youve had this bug for weeks. bruutal.
    2024-11-26T18:37:39+00:00
    Same. Flip6. Ugh. Was working great. Then just stopped.
