Phone link error 256 with S22 Ultra
2024-11-20T07:36:00+00:00
I have had Phone link working for years with my Samsung Galaxy S22 ultra.
Recently, part of the functionality stopped working, specifically, the "open phone screen" part. I keep getting an error 256.
The phone is on Wifi, connected to a Ubiquiti NanoHD.
The PC is a desktop on 10 Gbps ethernet.
Both are in the same /24 subnet, using DHCP with IP reservations in the router.
The phone says it's connected to the PC. The PC says the phone is connected to it.
I can see the phone's text messages & photos on the PC.
I just can't open the phone screen on my PC, or show any app on my PC's screen.
Windows for home | Windows 10 | Connect Phone and PC
    2024-11-24T22:43:05+00:00
    nothing yet...
    2024-11-24T23:58:45+00:00
    Samsung Flow seems really good so far. I may not go back to phone link
    2024-11-25T06:47:21+00:00
    same issue same phone same pc operating system
    2024-11-25T19:46:49+00:00
    Samsung flow is good, but the functionality is somewhat different. You need to manually start it on both sides. You can only open a single phone screen on the PC side - not multiple windows for each app. There is no separate handling for text messages or photos in Flow, also.
    The good news is that you can use both Phone link and flow at the same time, until Microsoft and/or Samsung fix the situation with phone screen not working in Phone link. When they do, I'll stop using Flow.
    2024-11-25T22:21:11+00:00
    Thank you all for reporting this issue. We are currently investigating this and will get back to you as soon as we have something to share. Thank you for your patience.
