let me know if there are any issues
KMODE_EXCEPTION_NOT_HANDLED help?
- <Event xmlns="**http://schemas.microsoft.com/win/2004/08/events/event**">
- <System> <Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331c3b3a-2005-44c2-ac5e-77220c37d6b4}" /><EventID>41</EventID><Version>8</Version><Level>1</Level><Task>63</Task><Opcode>0</Opcode><Keywords>0x8000400000000002</Keywords><TimeCreated SystemTime="2024-11-21T07:37:07.3471937Z" /><EventRecordID>56135</EventRecordID><Correlation /><Execution ProcessID="4" ThreadID="8" /><Channel>System</Channel><Computer>DESKTOP-NV14JER</Computer><Security UserID="S-1-5-18" /></System>
- <EventData> <Data Name="BugcheckCode">30</Data><Data Name="BugcheckParameter1">0xffffffffc0000005</Data><Data Name="BugcheckParameter2">0xfffff8027a9177e5</Data><Data Name="BugcheckParameter3">0xfffffc888ccbdb18</Data><Data Name="BugcheckParameter4">0xfffff8027e68b920</Data><Data Name="SleepInProgress">0</Data><Data Name="PowerButtonTimestamp">0</Data><Data Name="BootAppStatus">0</Data><Data Name="Checkpoint">0</Data><Data Name="ConnectedStandbyInProgress">false</Data><Data Name="SystemSleepTransitionsToOn">0</Data><Data Name="CsEntryScenarioInstanceId">0</Data><Data Name="BugcheckInfoFromEFI">false</Data><Data Name="CheckpointStatus">0</Data><Data Name="CsEntryScenarioInstanceIdV2">0</Data><Data Name="LongPowerButtonPressDetected">false</Data></EventData> </Event>
I was suddenly gaming when my PC suddenly crashed with the error code KMODE_UNHANDLED_EXCEPTION_CAUGHT. I do not know what caused it.
2024-11-21T13:25:57+00:00 -
DaveM121 934.5K Reputation points Independent Advisor2024-11-21T08:38:22+00:00 Okay, I will be here.
2024-11-21T08:27:54+00:00 Of course, I will go to do so whenever I wake up in the morning, I have a busy day tomorrow.
DaveM121 934.5K Reputation points Independent Advisor2024-11-21T08:19:14+00:00 Hi, I am Dave, I will help you with this.
Please check to see if your PC is producing any minidump files, I will check those to see if they provide any insight into a potential cause of the system crashes.
Open Windows File Explorer.
Navigate to C:\Windows\Minidump
Copy any minidump files onto your Desktop, then zip those up.
Upload the zip file to the Cloud (OneDrive, DropBox... etc.), then choose to share those and get a share link.
Then post the link here to the zip file, so we can take a look for you.
2024-11-21T07:48:28+00:00 Is it possible that outdated drivers could cause this error?
