Just checking with you, has your PC produced any new minidump files yet?
BSOD IRQL issue
my laptop have this issue where this it would Blue screen for some reasons
a few months ago i had the same error which i thought was because of my RAM so i replaced it, but it seems to have the same error again and im not sure why its doing it
the error i see is IRQL_not_less_or_equal
i assume its has something to do with my window or something else and im starting to run out of options
2025-01-01T23:14:50+00:00 No it hasn't, i dont know why it doesn't make a minidump file usually when it crash it would
2025-01-02T00:11:03+00:00 I dont know if this matters but i have checked in advanced settings that it does make a minidump file after crashing
DaveM121 933.9K Reputation points Independent Advisor2025-01-02T07:23:26+00:00 Sorry, I was offline, I think it may be time to consider backing up your data and clean install Windows from a bootable USB to rule out system corruption as the cause of the system crashes.
2025-01-02T08:46:12+00:00 Well...
I was starting to lose hope anyway
Thanks for helping these past days tho
I guess I'll just start backup my data
