Phone Pixel 6Pro
I loaded an earlier version. Now is working like it should https://phone-link.en.uptodown.com/windows/download/1038942233
All Versions
Phone is up to date
Computers are both up to date with MS update
BUT
Using Phone Link when I send a message to one of the people I message often rather than send message it creates a group. (see below)
On my phone it then shows as a group chat - which I can't edit
Works fine on my phone - but not on Phone Link - on both computers I own. Screenshot of how it ends up below.
I also have quite a few messages where both the name of recipient and my phone number comes up - just a bit of a pain.
I'd really appreciate any help on this
Thanks heaps
Gary
Phone Pixel 6Pro
All Versions
I have had the exact same issue for weeks, using a Samsung A52s, and it was driving me insane.
This solution worked and now it is back to normal!
Thank you!
Hi - can you tell me which version you downloaded.
I thought Phone Link was part of Windows system - so does the download override the system one?
Thanks.
I tried this and rolled back to 1.24101.60.0 with successful results.
Thank you - version 1.24111.82.0 has solved the problem for me.
Problem now is I have a permanent "1" notification badge because I can't turn notifications off for available updates!
Somewhat annoying - but far less annoying than having random groups being constantly created.
