I finally tried the Windows Update Assistant...
It downloaded, etc., said download was successful, did the shutdown and restart, but when restarted, it never really did a restart...the screens were just blank forever, so I did a manual restart to get the computer started again, that worked, but when starting, screen said "undoing changes to computer"....but it came back up w/no problem, but w/version 23H2....oh well....
Will just stay as is....I don't have a removable plug in to do the download for 24H2 the other two ways you suggested.....was just hoping to do it from an online download...never had that problem before. I downloaded Windows 11 Home from online a couple yrs. ago w/no problem. Computer is working fine, just won't do the newer version update, oh well...will just stay as is and deal w/it.
Thanks for your help if you have any other suggestions , let me know, but if not, I understand, thanks for your help.
Regards,
Claudia
