So my pc system settings say I'm on windows 11 pro but windows update says "Get the new version of windows to stay up to date Your version of windows has reached the end of service"
2024-12-20T14:24:32+00:00
So my pc system settings say im on windows 11 pro but windows update says "Get the new version of windows to stay up to date Your version of windows has reached the end of service"
Windows for home | Other | Apps
    2025-02-26T10:16:31+00:00
    Good Morning,
    Yes, what you say and how you put it does make sense...
    When I went to bed last night, the "UPDATE SYSTEM" says 23H2 downloaded and was successfully installed. But when I went to check it this morning, it still says, need new version, etc. and so on....so when I get home tonight, I will give it another try with the couple steps you mentioned, hope I don't mess it up.....
    Will let you know,
    Claudia
    2025-02-26T23:19:34+00:00
    Hi
    ,I will be trying a couple of your suggested steps soon.......system still says need updated version of Windows 11
    But to give you an idea of what I have, took a pic of what my system is, and a pic when I click on the Windows 11 Install Assistant..
    Wish me luck, I need it...hahaha...
    Claudia
    2025-02-27T11:21:30+00:00
    I went thru each step reading the instructions, etc....and well, it just won't compute in my brain, sorry, did not do any of them as have to create account, or can't do it not the administrator, etc.....
    You had mentioned in an earlier message if I wanted to go to 24H2, you would send me that link, so lets give that a try...
    I did try to send you this message last night after I sent you the pics, but it would not go thru.....would it be easier for you to email me directly, if so, please do....I am sorry...I just don't want to kill my computer by doing something wrong w/any of those steps, most can't do anyway as need password, etc.....
    Claudia
    ******@earthlink.net
    2025-02-27T14:25:43+00:00
    Your PC supports Windows 11, you can go ahead and click "Accept and Install". That should get you to 24H2 the quickest.
    If you would like, you can also use the Windows 11 Media Creation Tool or the Windows 11 ISO. Both are other ways to get 24H2.
    If you would like, you can start a new thread, and I can also share a video on how to install 24H2 to make things easier.
    Hope to hear back from you.
    2025-02-27T22:51:56+00:00
    Thanks for your reply...just got home from work...
    I will try the Installation Assistant first then the others if that does not work..'
    Actually, I will try later or tomorrow......Cox, the internet company is coming by soon to install a new modem, I share a small house w/a great roommate, but we have been having internet problems the past couple weeks, and for her, it is vital as she works from home 2 days a week, then goes into her office the other three, ....so I will wait till that is done, suppose to be tonight, maybe tomorrow.....our outside cable has been replaced, now they want to come in and replace the modem.....
    But I will also try to do a new thread as you say so I can see the video you are talking about....will give that a try....will have to figure that one out...hahaha, LOL..
    Will keep you updated, and I appreciate your help and your patience...
    Regards,
    Claudia
