Whatsapp callers suddenly hear echo on their end only
2025-01-31T23:27:39+00:00
After working fine for a couple of years, now whatsapp desktop is a problem - but not for me, for the person on the other end, who hears a full echo of everything they say.
I don't hear any echo. And, when I try the same call on my mobile instead of desktop, no problem.
This is recent, only the past 10 days or so.
Windows for home | Windows 11 | Input and language
    2025-03-16T14:01:04+00:00
    Well, for the record, this issue affects my Microsoft Surface laptop 4 using Windows 10 Pro
    and my Dell Latitude 5490 using Windows 11 Pro.
    I installed WhatsApp PC from the Microsoft Store
    version 2.2508.5.0 on the former on 02Mar2025 and
    version 2.2509.4.0 on the latter on 14Mar2025.
    Michael
    2025-03-16T23:00:48+00:00
    I have the same issue, on a Macbook Pro M4 and on Adroid. Caller at other end does not have any problems
    2025-03-18T13:48:01+00:00
    Me too! extremely annoying and it's recent. Same: Desktop only and without headsets.
    2025-03-18T14:27:45+00:00
    Subject: Audio Feedback/Echo Issue on WhatsApp for Windows – Ongoing Problem After Updates
    Hi everyone,
    As previously reported, I’m still experiencing the audio feedback/echo issue when using WhatsApp on my PC, which started after updating to Version 2.2502.3.0. The remote contact hears an echo, which wasn’t a problem before the update.
    I initially had some success by rolling back to Version 2.2447.5.0 (from Dec 6th, 2024), which resolved the issue temporarily. However, WhatsApp now flags that version as expired and forces an update to the latest version.
    I’ve reported this to WhatsApp a couple of times, but unfortunately, they’ve closed the tickets without providing any useful guidance. It appears this issue may be related to incompatibility between recent updates and certain Windows setups, as everything works fine on my other Windows devices.
    I’ve also tried the newly released Version 2.2509.4.0, but sadly, the issue persists.
    For now, I’ve resorted to using Zoom on my PC as a temporary workaround, but I’d much prefer to resolve this problem with WhatsApp.
    Has anyone found a solution or an effective workaround? Any insights would be greatly appreciated!
    Thanks in advance!
    2025-03-18T16:39:38+00:00
    My Audio configuration is based on Realtek HD integrated Audio for Speaker, Zoom U-22 Audio Interface for MIC and Voicemeeter Potato (Multi Channel Mixer, effects and Control).
    I have the same issue.
    If Install an old version (December 2024) the problem go away but WhatsApp update it in few ours.
    In the last WA version, If I close Voicemeeter Potato and Configure default Audio Output on Realtek and Input on Zoom U-22 devices all run fine.
    I don't like this solution but it indicate some problem in WA's Echo Cancelling in a multichannel configuration like Voicemeeter Potato. I hope this can help to find a solution. I have tried a lot but no luck
