Whatsapp callers suddenly hear echo on their end only
2025-01-31T23:27:39+00:00
After working fine for a couple of years, now whatsapp desktop is a problem - but not for me, for the person on the other end, who hears a full echo of everything they say.
I don't hear any echo. And, when I try the same call on my mobile instead of desktop, no problem.
This is recent, only the past 10 days or so.
Windows for home | Windows 11 | Input and language
    2025-06-02T09:51:41+00:00
    StartFragment
    This may work for some but I think the reality is if you've already reinstalled WhatsApp multiple times, both Reset and Repair (even if it were available) would likely have the same effect. They all aim to restore the app to a default state, and clearly, the issue goes deeper than just corrupted files.
    That reinforces my original suspicion: it's almost certainly a compatibility issue between certain versions of WhatsApp and specific PC hardware or drivers — especially considering it works fine on my older machine with the same mic/camera setup.
    EndFragment
    2025-06-02T15:41:32+00:00
    Agreed, same for me no Repair option.
    2025-06-08T11:35:02+00:00
    Sometimes the solution is simple. For those who still face the problem, I wish that another solution is soon found!
