Stuck in a loop where my laptop keeps freezing at 99 percent when updating, system restore fails
2025-01-22T07:39:29+00:00
Nine months ago I faced a similar problem and posted about it here (
https://answers.microsoft.com/en-us/windows/forum/all/stuck-in-a-loop-where-my-laptop-keeps-freezing-at/04ce9357-a3b9-416a-a591-8abe67317fb8 ) and I was fortunate to get the help I needed. I went back to my old question post and followed the instructions but this time my laptop fails to complete system restore. The windows that pops up reads:
"System Restore did not complete successfully. Your computer's system files and settings were not changed.
Details:
System Restore failed while mounting the registry from the restore point. An unspecified error occurred during System Restore. (0x800703f1)
You can try System Restore again and choose a different restore point. If you continue to see this error, you can try an advanced recovery method."
There was only one restore point available from the 20th, the day before this happened, so that last line is not an option.
Another instruction from the old post was "If you haven't set it up before, click on troubleshoot, click on uninstall updates and try to uninstall the updates you have installed, after that click on command prompt and enter the following commands in order..." however the laptop is also unable to uninstall these latest updates, both quality and feature updates. Should I go ahead and enter the commands anyway? Should I try startup repair? Reset PC? What should I do?
Also, Aaron, if you're reading this, I apologize that I hadn't marked your reply as helpful all those months ago, I was sure I had but judging from your repeated replies requesting I do so I apparently hadn't. I haven't been on this site since then so I never saw those replies. Again, I'm sorry.
Ramesh 181.6K Reputation points Volunteer Moderator
2025-01-24T05:41:22+00:00
See if you can close Notepad.
To backup the files from Windows.old, run the following in Command Prompt:
robocopy c:\windows.old\users\oliver F:\Oliver /XD "appdata" /MIR
(Assuming F:\ is your 2nd partition on your USB setup disk.)
2025-01-22T15:30:18+00:00
Is there disk activity? If it's hung up/no disk activity, your best option is to clean install using USB.
Ramesh Srinivasan 87,775 Reputation points Independent Advisor
2025-01-22T08:45:30+00:00
Hi Oliver,
Sorry, I thought Windows was booting fine despite the Windows Update issue.
If you can start WinRE, open WinRE Command Prompt and run:
bcdedit | find "osdevice"
Note the drive letter of the OS partition from the above output. Suppose it's C:\
Run this command to revert pending servicing operations.
md C:\Temp
dism /Image:C:\ /Cleanup-Image /RevertPendingActions /ScratchDir:C:\Temp
ren C:\Windows\WinSxS\pending.xml pending.xml.old
Post the output here.
78 additional answers
    2025-01-22T10:57:08+00:00
    Oops, my bad. I input the command again with he colon and the the next lines read:
    "Deployment Image Servicing and Management tool
    Version: 10.0.19041.1
    Error: 32
    An initialization error occurred.
    For more information, review the log file.
    The DISM log file can be found at C:\Temp\Dism.log"
    Do you want me to send you another image of the note log?
  2. Ramesh 181.6K Reputation points Volunteer Moderator
    2025-01-22T11:02:59+00:00
    Please reboot the system and try that command again. It's because the hive is loaded.
