Glad to help.
Best regards.
Hi, my pc has been giving me BSOD like 10 times a day for the past 10 or more days because of corrupted files or ram issues (I'm not sure), I tried checking for the drive integrity and this came out:
"Error Checking (Windows (C:)
Repair this drive
Windows found errors on this drive that need to be repaired. Close this dialog box, and then repair the drive."
So out of curiosity I tried doing the same to my other drive and came out with the same issue. How do I fix this? Do I need to reset my PC? Do I have to buy a new drive? Or do I need to perform a fresh install of windows 11?
Bsod errors I've been getting:
KERNEL_DATA_INPAGE_ERROR
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
SYSTEM_SERVICE_EXCEPTION
And other I can't remember now
They usually happen when I start my PC, and I'll get 5 or 10 of them one after the other before my PC starts working "properly"
After I manage I get through the bsod errors my PC seems to run just fine for some time before giving me more errors (usually 3-4 hours)
I can provide dump files if explained how to do so
Glad to help.
Best regards.
Try at least one more time.
If the problem occurs again, this confirms that there is a hardware problem with your PC.
Feel free to ask back any questions. Click on the "Reply" button below my reply.
Hi David, I tried two more times and it still gave me the error
By hardware problem you mean that my drive is broken right? Do you think it's repairable or should I just buy a new one?
Also can I install windows 11 on another drive in the meantime then?
If I can't use this one then maybe the other one might work no?
Unfortunately, I can't remotely pinpoint where the problem is. Crystal Disk Info didn't detect any problems, but there could still be a problem with the drive. There are some problems that Crystal Disk Info cannot detect.
However, the problem could also be with the motherboard or other hardware.
Only a physical analysis of the device can determine exactly where the problem is.
Feel free to try installing Windows on the other drive. But make a backup of any important files stored on the other drive that you don't want to lose.
If you have any questions, don't hesitate to ask. Click on the "Reply" button below my reply.
Hi David, I just tried installing it on another drive and it still gave me an error
Is it safe to assume that my PC needs to go through a technician to get the issue fixed?
